I bought one of these sensors, and paired it up to ZHA, but am having a few issues with it.
I am receiving each of the expected values (temperature, humidity, TVOC) , but after transmitting for a couple days, the device stops sending values, and needs to be woken back up using the button on top of the unit. Sometimes after waking the unit back up to get it to transmit again, it reports 9999 ppb TVOC, which eventually returns to a normal value.
I cannot tell what firmware the device is running. I have a couple IKEA devices which do report firmware, not sure what is different about this device that it does not. I was wondering if the issue above could be resolved if there was a firmware update available. However, my understanding is that ZHA only supports updating firmware on a couple different device vendors anyway.
I am unable to change the displayed units of temperature from °C to °F. There are no configuration options shown for the device, but it seems like this should be one.
When reconfiguring the device, I get an error that the XiaomiAqaraE1Cluster did not configure properly, and the process fails. Perhaps this is related to some of the above issues? Any ideas for how to make this complete successfully? I have tried many times and always get the same result.
DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0A82:1:0xfcc0]: Failed to bind 'manufacturer_specific' cluster
Trying to decide whether this is an issue with ZHA that can be fixed, or something else (firmware needs to be updated, Zigbee channel needs to change, etc). Or maybe this device is not worth my time, and I should just return it.
