Aqara vibration sensor detected as unknown door lock
I have an Aquara vibration sensor (DJT11LM) that when I connect it it isn’t detected properly.
It’s detected as unk_model door lock.
I tried changing the battery, re-pairing the sensor and reconfiguring in HA.
the log shows the following error:
WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x8884:1:0x0101]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
more log here: Line 18857: 2023-03-19 20:29:14.114 DEBUG (MainThread) [homeassistant.components - Pastebin.com
Anyone else had the same issue? can this sensor be configured manually?
this is it’s current Zigbee info:
IEEE: 00:15:8d:00:03:d3:4d:9f
Nwk: 0xa6df
Device Type: EndDevice
LQI: 49
RSSI: Unknown
Last Seen: 2023-03-20T11:41:39
Power Source: Battery or Unknown
and this is the zigbee coordinator:
Texas Instruments Z-Stack ZNP
HA version 2023.3.3.
I have recently had this issue as well. Still unresolved. Previously I had it paired correctly. Details below:
Zigbee Radio:
Conbee II Usb Stick
Zigbee Integration:
ZHA
Device info
lumi.vibration.aq1
by unk_manufacturer
Zigbee Info
Nwk: 0xe92a
LQI: 255
RSSI: -44
Last seen: 2023-12-24T16:11:28
Power source: Battery or Unknown```
Die you find a solution?
