I 'member a secret keystroke in deCONZ to get you to a place where you could adjust the sensitivity of Aqara Vibration Sensors so I know it can be done.
The question is; does anyone know of a way to do this in zha?
There is a way to configure sensitivity through the ZHA web UI, using the cluster editor:
Later in the thread are some screenshots too.
edit: looks like you found the thread already. I’ll leave this link here in case anyone searching lands here first.
Hi there,
i can’t found the Cluster in my Informations:
Updated Instructions below:
I’m trying to change the sensitivity of the lumi.vibration.aq1 sensor but without success, I always get the error: Failed to execute action zha/set_zigbee_cluster_attribute. Failed to set attribute: value: 1 attribute: 65293 cluster_id: 0 endpoint_id: 1
I’m using Home Assistant OS 16.0 and core-2025.7.2
Below is the system log, can anyone help understand the error?
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:258
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 13:20:26 (2 occurrences)
Last logged: 13:20:56
[140115677406176] Unexpected exception
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/zigbee/application.py", line 924, in send_packet
await self._send_request_raw(
...<11 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/zigbee/application.py", line 838, in _send_request_raw
raise InvalidCommandResponse(
...<2 lines>...
zigpy_znp.exceptions.InvalidCommandResponse: Unsuccessful request status code: <Status.MAC_NO_ACK: 233>
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/device.py", line 1001, in write_zigbee_attribute
response = await cluster.write_attributes(
{attribute: value}, manufacturer=manufacturer
File "/usr/local/lib/python3.13/site-packages/zigpy/zcl/__init__.py", line 651, in write_attributes
return await self.write_attributes_raw(attrs, manufacturer, **kwargs)
File "/usr/local/lib/python3.13/site-packages/zigpy/zcl/__init__.py", line 660, in write_attributes_raw
result = await self._write_attributes(
attrs, manufacturer=manufacturer, **kwargs
File "/usr/local/lib/python3.13/site-packages/zigpy/quirks/__init__.py", line 388, in _write_attributes
return await super()._write_attributes(
attributes, *args, manufacturer=manufacturer, **kwargs
File "/usr/local/lib/python3.13/site-packages/zigpy/zcl/__init__.py", line 378, in request
return await self._endpoint.request(
...<9 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy/endpoint.py", line 270, in request
return await self.device.request(
...<11 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy/device.py", line 378, in request
await send_request()
File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 844, in request
await self.send_packet(
...<14 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/zigbee/application.py", line 987, in send_packet
raise DeliveryError(f"Failed to send request: {status!r}", status=status)
zigpy.exceptions.DeliveryError: Failed to send request: <Status.MAC_NO_ACK: 233>
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 258, in handle_call_service
response = await hass.services.async_call(
...<7 lines>...
File "/usr/src/homeassistant/homeassistant/core.py", line 2799, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2842, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1120, in _async_admin_handler
return await task
File "/usr/src/homeassistant/homeassistant/components/zha/websocket_api.py", line 1333, in set_zigbee_cluster_attributes
response = await zha_device.write_zigbee_attribute(
...<6 lines>...
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/device.py", line 1014, in write_zigbee_attribute
raise ZHAException(
...<5 lines>...
) from exc
zha.exceptions.ZHAException: Failed to set attribute: value: 1 attribute: 65293 cluster_id: 0 endpoint_id: 1
Thank you!
I ran into similar issues until I discovered most of them would go away if I “woke up” the sensor (pressing the config/setup button once) a short time (within a minute or two) of sending the command to it.
Thanks for your reply. I tried everything but I couldn’t change the attribute, so I changed it to zigbee2mqtt. Now everything is working perfectly and I managed to change the sensitivity.
