Some Aqara wall plugs of mine are not showing power consumption correct. They are just adding total power to the consumption calculation instead of only the consumption from the last reading.
Correct consumption graph.
This is how it should look like.
When adding total power to the consumption calculation, it gives me a very big power usage and is useless to me.
Wrong consumption graph.
Only 1 out of 5 wall plugs are showing correct consumption. All are connected via ConBee II/deCONZ and have the same firmware release.
Anyone with similar problem or maybe a solution how to fix it?
What do you mean? How are you adding this to a total?
Note you are talking about energy consumption (kWh) and not power consumption (W or kW).
How are your power consumption (W) sensors?
My energy sensors (none of them from Aqara) are also cumulative, just like yours, and they work just fine with the Energy dashboard.
My power sensors, however, are all instanteous measurements (probably what you are looking for).
The consumption in kWh is supposed to be a steady growing graph (like the screenshot above), but looks like this.
It has been working fine for some years. After some update it started to measure wrong, adding 10 times the actual value. That was corrected in an update but introduced then this strange behaviour on the consumption side.
This is a screenshot from my Energy dashboard. My usage is NOT over 12.000 kWh in the last 24H
