Aqara wall switch and sonoff button
Hello
I am using aqara wall switch via HA Skyconnect. It is working fine. If I pair a sonoff zigbee button as well. The button press toogle the switch without automatization. I tried to turn off the HA and the situation is the same. Do youbhave idea how can I delete the switch and button pairing?
Are you using ZHA or Z2M as an integration?
I am using ZHA with Zigbee Home Automation.
I have the same question. The Sonoff switch tiles activate the Aqara switch without any input from me. They have the same effect when Home Assistant is not running.
I’m running them all via the Zigbee Home Automation service and the Sonoff 3.0 USB dongle.
Does anybody have any suggestions as it’s driving me crazy! I can’t see any way to configure the switches though HA.
Anybody have any experience with the Aqara wall switches? I’m tempted to buy their hub to remove the automations!
Getting something similar with the Sonoff SNZB-01P by eWeLink. It just seem to switch the Aqara smart wall socket on and off (and the configured action) without anything to change it.
Do you solve it?
I’ve tried everything I can think of.
I started my migrating network from ZHA to Zigbee2mqtt. This provided many more options for binding. I had everything working well for awhile (self healing network was using alternate routes) but ultimately the buttons revert to using the switches as the first router (because they are physically close). Once this happens, the button triggers the switch, along with any other automations.
My next step is to add another coordinator and put the buttons on a different network.
I wish there was a better solution.
Thought I was going crazy for some reason the sonoff button and the Aqara t1 mini button does the same with the Aqara Wall Switches, if I pair the button to via another coordinator then all is fine.
Any other solutions found?
