I just set up the Xiaomi Aqara smart wall switch H1 EU (no neutral, single rocker) and I noticed the zigbee2mqtt shows as EndDevice.
I thought all powered devices were likely to be routers. Does anyone know if this is due to the fact there’s no EndDevice connected to it or if this is indeed an end device?
If it’s the latter, is there any way to know upfront? My plan was to install the smart switches first over my place so I would have a good coverage.
It also depends on what the manufacturer has done with the firmware. If it has defined it as a end-point. I have just ordered one so hopefully Wednesday I can give my experience.
Yeah, this was my feeling @robertklep but I was hopping to be wrong. I just set up an Ikea led and it shows as router so I’ll change my strategy and focus in the lighting first.
I have just been able to install mine (had to purchase a spacer since the box in the wall wasn’t deep enough) and can confirm it is an EndDevice. Most likely this is also done to reduce the power consumption, as a router it would constantly need to receive and transmit. As an EndDevice it only needs to when required, or when being polled. It has to use the current via the exisiting lights so the less it consumes the better, less risk that any light might glow or flicker.
