I have simple and double aqara wall switches. For a couple of days, I’ve noticed that I had to press two times the button in order to get the automation fired. After I’ve pressed the button for the second time, it works for all the next presses as well. But the problem will come back if I don’t use the wall switch for 5 minutes.
My hardware configuration is an Intel NUC with a Deconz Conbee II.
I’ve subscribed to the deconz_event in the developer tools and I can confirm that the event is not fired, meaning deconz didn’t get the Zigbee message.
I have no idea how to interpret this. I don’t want to abuse of your time so if you have a link for a page that explains how to decrypt this, that would be nice !
Start by moving around the different items so rhat the connections get visible. On the first look it looks like all of them route the traffic dirwvtly to the stick and not through any other mains powered device. Are the hue devices in the same mesh or connected to the hue hub?
Haaa, nice point !!! Indeed my hue devices are connected through the philips hue bridge, integreted directly to Home Assitant. Therefore, my conbee don’t have knowledge of the existence of my hue devices. Do you think I should get rid of my hue bridge and connect directly my hue lights to my conbee ?
These are two different mesh then, and they don’t know of each other. I ditched my hue hub around 3 years ago and moved all devices to the ConBee. Never looked back. Best thing is that the hue remotes and sensors now push their state to Home Assistant instead of polling it from the Hue bridge.
