I’ve made a script I want to share, to control the lights using a wall switch.
The switch is a aqara zigbee wall switch that is connected with Zigbee2MQTT. The lights are an Ikea Tradfri bulb (also Zigbee2MQTT) and a light with a sonoff. The button can detect long presses and double presses, this allows to control brightness and color of the light with a single button, but only if the light supports it.
Automation:
- id: '1552853418090'
alias: SlaapkamerLampknop
- entity_id: sensor.slaapkamerlampknop
platform: state
condition: []
- data_template:
button: '{{ trigger.to_state.state}}'
entity: '{{ trigger.to_state.entity_id}}'
service: python_script.slaapkamerlampknop
python script:
#compare color
def compare_color(color1,color2):
return (-5 <= (color1[0]-color2[0]) <= 5 and -5 <= (color1[1]-color2[1]) <= 5 and -5 <= (color1[2]-color2[2]) <= 5)
#get state and entity_id of button from automation
buttonState = data.get('button')
buttonEntity = data.get('entity')
#get target light based on trigger device and button
if buttonEntity == 'sensor.slaapkamerlampknop' and buttonState.startswith('left'):
entity_id = 'light.myfirstbulb'
elif buttonEntity == 'sensor.slaapkamerlampknop' and buttonState.startswith('right'):
entity_id = 'light.nachtkastlamp'
else:
entity_id = ''
if entity_id != '':
#find out which features are supported by the target light
light = hass.states.get(entity_id)
features = light.attributes.get('supported_features')
if buttonState.endswith('long') and features % 2 >= 1:
#change brightness on long button press
service = 'turn_on'
brightness = light.attributes.get('brightness') or 0
if brightness < 150:
service_data = {'entity_id': entity_id, 'brightness': 200}
else:
service_data = {'entity_id': entity_id, 'brightness': 100}
elif buttonState.endswith('double') and features % 32 >= 16:
#change color on double press
service = 'turn_on'
rgb = light.attributes.get('rgb_color') or [0,0,0]
colors = {
"white":[255,254,254],
"yellow":[255,255,128],
"orange":[255,128,0],
"red":[255,0,0]
if compare_color(rgb,colors["white"]):
service_data = {'entity_id': entity_id, 'rgb_color': colors["yellow"]}
elif compare_color(rgb,colors["yellow"]):
service_data = {'entity_id': entity_id, 'rgb_color': colors["orange"]}
elif compare_color(rgb,colors["orange"]):
service_data = {'entity_id': entity_id, 'rgb_color': colors["red"]}
elif compare_color(rgb,colors["red"]):
service_data = {'entity_id': entity_id, 'rgb_color': colors["white"]}
else:
else:
service = 'toggle'
service_data = {'entity_id': entity_id}
hass.services.call('light', service, service_data, False)
