I have an Aqara Water Leak Sensor (lumi.sensor_wleak.aq1) connected via Conbee II.
Everytime the sensors gets wet, the moisture status in HA doesn’t change back to dry in a timely manner, if the device gets dry again. Sometimes it takes hours to days and I don’t know how to force HA to change the status.
The sensor is definitely dry. Currently it is lying on a non-conductive surface. It even doesn’t matter if I extend the detection screws via wire. Is it possible to force HA to reset the status?
It may sound daft but try rinsing it and drying with a towel. I needed to do this when mine wouldn’t change back after being out of water for a while. I supposed there was a conductive deposit on the surface.
Thanks for the hint. This seems to solve the problem. I re-tested it several times and status changed immediately from wet to dry and vice versa. Hopefully it stays that way Thanks so far!
Funnily enough I’m having the same issue with an aeotec pro water sensor. It occasionally gets stuck in dry mode even though it’s wet. Had to do a hard reset and dry it out and then it was fine.
Its done this twice and really doesn’t fill me with confidence.
