Long story short is I have an Aqara hub (v1 I think) alongside about 30 various Aqara sensors including door/window, temp, water leak, etc. About 6 months ago they all kept disconnecting and reconnecting every 30 seconds. I had to start fresh and change from the Aqara app to the Mi Home app, repair and rename them into HA, and re-add them to every automation. Fast forward to now and his behavior is happening again. I have the hub paired through Homekit into HA and all of the Aqara entities will disconnect at once and then come back. Randomly it will work for a few hours then start disconnecting again. The sensors on the app itself are fine. It doesn’t seem like a hub problem but for some reason it doesn’t work well with HA consistently. I have moved the hub right next to the router too and the issue remains.
So fellow Aqara users, if you were to start again fresh knowing what you know now, how would you implement Aqara sensors into HA? Would you use the Aqara hub (which version?) or something like Z2M? If so, which dongle? The hub worked for well for a long time for me but I can’t keep dealing with everything failing every few months but I’m also not sure what the root of the problem is.
