I’m completely new to home assistant and have done my best to search for someone having the same issue but could not find anything.
I have home assistant yellow and connected my aqara window sensor.
Unfortunately every time I open the window, the sensor shows both open and closed simultaneously.
As my experience is extremely limited, I set everything up via the UI and not yaml.
At first I thought I had set up my notification automations incorrectly but after deleting my automations and looking at the logbook I can see that the sensor itself reports as both open/closed every time the window is either opened or closed.
Is there something more I need to configure to get the sensor to work correctly?
Thank you.
