Aqara Wireless Remote Switch H1 help
I’m quite new to Home Assistant. I recently bought a Aqara two gang Zigbee “Wireless Remote Switch H1 (Double Rocker)” switch which I would like to add to Home Assistant via the SONOFF ZigBee 3.0 USB Dongle Plus and the Zigbee Home Automation integration. I was able to add everything to Home Assistant really smoothly But when I wanted to configure the switch in the configuration menu, no button press events showed (only battery and identify). I did some research and found an amazing tip that told me I should use the event listener. This worked, but then I ran into another issue. In the event listener, there is no difference between a press on the first or second button (see picture, one is from first button, other is from second button). Would anyone know how I could solve this issue?
Thanks in advance!
