I’ve been using Zigbee2MQTT - Aqara Wireless Switch (single, double, triple, quadruple) for a while now and it’s been good. However, the upcoming Zigbee2MQTT 2.0 release will drop support for the legacy sensors that blueprint uses. Here is a nearly identical blueprint that implements support for the WXKG11LM using device triggers. It will work in the 1.x releases of Zigbee2MQTT too.
Edit: This was reverted in fix(ignore): Add back Home Assistant legacy action sensor by Koenkk · Pull Request #25192 · Koenkk/zigbee2mqtt · GitHub and the sensor entities have been restored. Of course, this blueprint still works, but users upgrading to the 2.0 release when it’s out won’t have any breaking automations to fix up.
As well, it adds support for hold
and release
actions which are supported on some newer revisions of the button (but can’t be identified from the model number).
blueprint:
name: Aqara Wireless Switch WXKG11LM (via Zigbee2MQTT device trigger)
description: Control anything using Aqara Wireless Switch
domain: automation
input:
device:
description: Aqara Wireless Switch to use
selector:
device:
filter:
- manufacturer: Aqara
model: Wireless mini switch (WXKG11LM)
- manufacturer: Xiaomi
model: Mi wireless switch
multiple: false
press_single:
name: Single button press
description: Action to run on single button press
default: []
selector:
action: {}
press_double:
name: Double button press
description: Action to run on double button press
default: []
selector:
action: {}
press_triple:
name: Triple button press
description: Action to run on triple press
default: []
selector:
action: {}
press_quadruple:
name: Quadruple button press
description: Action to run on quadruple press
default: []
selector:
action: {}
press_hold:
name: Hold button press
description: Action to run on button hold (not supported on all devices)
default: []
selector:
action: {}
press_release:
description: Action to run when button is released (not supported on all devices)
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/aqara-wireless-switch-wxkg11lm-via-zigbee2mqtt-device-trigger/808126
mode: queued
max_exceeded: silent
- platform: device
domain: mqtt
device_id: !input device
type: action
subtype: single
- platform: device
domain: mqtt
type: action
subtype: double
- platform: device
domain: mqtt
type: action
subtype: triple
- platform: device
domain: mqtt
type: action
subtype: quadruple
- platform: device
domain: mqtt
type: action
subtype: hold
- platform: device
domain: mqtt
type: action
subtype: release
- choose:
- conditions: "{{ trigger.payload == 'single' }}"
sequence: !input press_single
- conditions: "{{ trigger.payload == 'double' }}"
sequence: !input press_double
- conditions: "{{ trigger.payload == 'triple' }}"
sequence: !input press_triple
- conditions: "{{ trigger.payload == 'quadruple' }}"
sequence: !input press_quadruple
- conditions: "{{ trigger.payload == 'hold' }}"
sequence: !input press_hold
- conditions: "{{ trigger.payload == 'release' }}"
sequence: !input press_release
