Aqara/Xiaomi Button Multi-Action Blueprint for Home Assistant
Overview
This blueprint allows you to create automations in Home Assistant that react to single, double, or hold actions of an Aqara/Xiaomi button. Specifically, it toggles associated input_boolean
entities based on the last_action
attribute of the button.
Compatible Devices
- Aqara Motion Sensor P1 (Tested)
Features
- Toggle an
input_boolean
when an Aqara/Xiaomi button is single-pressed. - Toggle a different
input_boolean
when the button is double-pressed. - Toggle yet another
input_boolean
when the button is held.
Known Issues
Last Action Attribute
If the last_action
attribute doesn’t change (for example, from “single” to something else), the state of the binary_sensor won’t change. Consequently, the trigger for the automation won’t fire again. This is a limitation that we are aware of, and we welcome any ideas or contributions to improve this behavior.
Installation
Via Home Assistant UI
- Go to Home Assistant Dashboard > Configuration > Blueprints.
- Click on “Import Blueprint” and paste the GitHub URL for this blueprint.
- Click “Preview Blueprint” and then “Import Blueprint”.
Via File System
- Clone this repository or download the YAML file for the blueprint.
- Move the downloaded YAML file to your
config/blueprints/automation/
directory. Create the directory if it doesn’t exist. - Restart Home Assistant.
Usage
- After installing the blueprint, go to Configuration > Automations.
- Click on the “Add Automation” button.
- Select the “Aqara/Xiaomi Button Multi-Action” blueprint under “Blueprints”.
- Configure the automation by selecting the Aqara/Xiaomi button entity and the
input_boolean
entities you want to toggle. - Save the automation.
Contributing
Feel free to contribute to this blueprint by creating a pull request or opening an issue.
License
This blueprint is under the MIT License. See the LICENSE file for more details.
