Aqara/Xiaomi WS-EUK02 action not recognised in HA
Hello everyone,
Today, I installed the Aqara Double Rocker Wall Switch (WS-EUK04) using zigbee2mqtt. Only 1 button is “connected to the wire”. The second one will be used with automations.
Generally, everything seems fine, except for the following issue:
  • I can turn the lights on/off via the button on the switch. Operation mode: control_relay
  • I can also turn the lights on/off via HA (compare image below)
  • However, if I e.g. turn on the lights with the button, the state is not recognised in HA and it looks, that e.g. the lights are still off.
What am I missing, please?
Edit: I performed a bit more testing and “listened to the topic”. No messages were posted, when using the button(s) on the device. Did I miss a setting anywhere to activate that communication?
Edit 2: Aqara WS-EUK04 not emitting actions in decoupled mode · Issue #17305 · Koenkk/zigbee2mqtt · GitHub
I was able to fix the issue by upgrading my Sonoff USB-Dongle-P to the newest firmware
Hi man, I’ve been struggling with this for about a week now. How do you update that dongl?
