Hi. Yesterday I added Aqara ZHWG11LM hub and Aqara WXKG02LM double switch to my Home Assistant and I automated it to switch on and off my bulb. When creating an automation I selected wireless remote switch as device and then “single_press” button 2 as trigger. I had also another triggers to choose like “double_press” button 2, “single_press” button 1 etc. Today I noticed that without reason all those triggers disappeared and went unknown. All I can choose is Wireless Remote Switch-F8C7 Stateless Programmable Switch-1-F8C7 entity and it even doesn’t distinguish single press from double press. It’s always single press. Below I attach screenshot of how I configured automation yesterday and how I can do it now.
I don’t know what happened and why all triggers disappeared. The only thing that changed from yesterday is adding temperature and humidity sensor WSDCGQ11LM in Mi Home app, which automatically appeared in Home Assistant too. Do anyone have an idea why switch suddenly became almost useless?
i had something similar … I have an aqara hub M2 running for over a week as matter integration. today I added a double rocker switch. so far anything ok, afer few hours I changed the funtionallity of the switch from single to multipress, my matter service lost all devices. just a reboot brings them all back … might be because of the device changes itself … I will observe
I tried rebooting both Aqara Hub and Home Assistant but it didn’t change anything. Triggers are still missing.
EDIT
Before I tried restarting Home Assistant first and then Aqara and it didn’t help. Now after Aqara restart I restarted HA and suddenly all triggers are back. Interesting how long it will be working.
Today this happened again. I had to restart Aqara hub and then HA two times! After first restart one automation was disabled and in logs I found something about that homekit controller doesn’t support automation. After second restart everything works again.
Hi guys, i’m having the same issue constantly. It occurs randomly in the exact same way. Restarts of HA always help. Did you find the culprit or any way how to get rid of this “feature”?
