Format your code correctly. How to help us help you - or How to ask a good question
You should be able to customize the devices through the Z2M frontend. Zigbee2MQTT devices are located in Zigbee2MQTTs files (configration.yaml, devices.yaml) not in the Home Assistant configuration.yaml.
