Aquara blind motor in zigbee2mqtt
I’m trying to integrate my aquara blind motor in to home assistant. It appears in zigbee2mqtt but no entities appear in home assistant. When I set the the external converter option zigbee2mqtt stops working and displays a 502: Bad Gateway error. I’m using a conbee II zigbee gateway.
I have entered ‘Xaiomi’ in the external converter option
I have created file called Xaiomi.js and saved it next to the zigbee2mqtt configuration.yaml file. Below is the content of the file which i copied from zigbee-herdsman-converters/xiaomi.js at 7a148842f0be231d09426faf62cac231587e0c64 · Koenkk/zigbee-herdsman-converters · GitHub
 zigbeeModel: ['lumi.curtain.acn002'],
    model: 'ZNJLBL01LM',
    description: 'Aqara roller shade companion E1',
    vendor: 'Xiaomi',
    fromZigbee: [fz.xiaomi_curtain_position, fz.xiaomi_curtain_acn002_status, fz.ignore_basic_report, fz.aqara_opple],
    toZigbee: [tz.xiaomi_curtain_position_state, tz.xiaomi_curtain_acn002_battery, tz.xiaomi_curtain_acn002_charging_status],
    onEvent: async (type, data, device) => {
        if (type === 'message' && data.type === 'attributeReport' && data.cluster === 'genMultistateOutput' &&
            data.data.hasOwnProperty('presentValue') && data.data['presentValue'] > 1) {
            // Try to read the position after the motor stops, the device occasionally report wrong data right after stopping
            // Might need to add delay, seems to be working without one but needs more tests.
            await device.getEndpoint(1).read('genAnalogOutput', ['presentValue']);
    exposes: [e.cover_position().setAccess('state', ea.ALL), e.battery().withAccess(ea.STATE_GET), e.device_temperature(),
        exposes.binary('charging_status', ea.STATE_GET, true, false)
            .withDescription('The current charging status.'),
        exposes.enum('motor_state', ea.STATE, ['declining', 'rising', 'pause', 'blocked'])
            .withDescription('The current state of the motor.'),
        exposes.binary('running', ea.STATE, true, false)
            .withDescription('Whether the motor is moving or not')],
    configure: async (device, coordinatorEndpoint, logger) => {
        device.powerSource = 'Battery';
        device.save();
        const endpoint = device.getEndpoint(1);
        await endpoint.read('aqaraOpple', [0x040a], {manufacturerCode: 0x115f});
    ota: ota.zigbeeOTA,
The configuration.yaml is
  "external_converters": [
    "Xiaomi"
  "devices": [
    "devices.yaml"
  "groups": [
    "groups.yaml"
  "homeassistant": true,
  "permit_join": false,
  "mqtt": {
    "base_topic": "zigbee2mqtt",
    "user": "my username",
    "password": "my passwordd",
    "server": "mqtt://core-mosquitto:1883"
  "serial": {
    "port": "/dev/ttyACM0",
    "adapter": "deconz"
  "advanced": {
    "log_level": "debug",
    "pan_id": 6754,
    "channel": 11,
    "network_key": [
      1,
      3,
      5,
      7,
      9,
      11,
      13,
      15,
      0,
      2,
      4,
      6,
      8,
      10,
      12,
      13
    "availability_blocklist": [],
    "availability_passlist": []
  "device_options": {},
  "blocklist": [],
  "passlist": [],
  "queue": {},
  "frontend": {
    "port": 8099
  "experimental": {}
