Aquara wall switches inverse function
Hello
I am using Aquara wall switch H1 and H2 with Home Assistant (Zigbee integration). Now if I turn onthe led light is on if I turn off the led light in the switch is turn off. Is it possible to reverse the functionality? I used zigbee2MQTT before HA and in that application is was possible.
thanks in advance.
