Aquarium dimmer
In ESPhome i have a device for controlling my aquarium light.
For this i use a Wemos D1 mini, with a mosfet to control the 24V power suply.
The led light is dimmed with PWM
see below.
what i aqtualy want is a on/off command that start sunrise and sunset default_transition_length : 1h
and need a way to control the led strip imidiatly. without the transistion time, is there a way to do this ?
output:
  - platform: esp8266_pwm
    pin: D4
    frequency: 1000 Hz
light:
  - platform: monochromatic
    output: pwm_output
    gamma_correct: 0
you can remove the default_transition_length there and leave it at the default 1 second, for the “immediately”
for the automation you then call the light service specifying the transition time:
    - light.turn_on:
        brightness: 100%
        transition_length: 1h
you need the automation for sunrise and sunset, you can use esphome sun component or create services invoked from ha and use the ha to trigger them
