sponnet
(Stefaan Ponnet)
September 16, 2022, 11:37pm
1
While browsing this forum I got my Aquascenic values read out to home assistant using the modbus interface. For reference I’ll share my approach here.
I used a Wemos D1 board with ESPhome flashed onto it
Then I attached a MAX485 module that I found here: MAX485 module voor RS485 seriële communicatie - HobbyElectronica
Then I came up with this configuration for the ESPhome device.
My ESPhome configuration file is as follows:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_ssid
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 19200
stop_bits: 1
modbus:
flow_control_pin: GPIO0
modbus_controller:
## the Modbus device addr
address: 0x1
modbus_id: modbus1
command_throttle: 0ms
# ctrl_pin: 5 # if you need to set the driver enable (DE) pin high before transmitting data configure it here
setup_priority: -10
- platform: modbus_controller
name: "Water Temperatuur Zwembad"
address: 0x0106
offset: 0
unit_of_measurement: "°C"
value_type: U_WORD
accuracy_decimals: 2
register_type: read
filters:
- multiply: 0.1
name: "pH Waarde Zwembad"
address: 0x0102
offset: 0
unit_of_measurement: "pH"
register_type: read
value_type: U_WORD
filters:
- multiply: 0.01
name: "Vrije Chloor Waarde Zwembad"
address: 0x0104
offset: 0
unit_of_measurement: "ppm"
register_type: read
value_type: U_WORD
filters:
- multiply: 0.01
name: "Hydrolyse Percentage Zwembad"
address: 0x0101
offset: 0
unit_of_measurement: "%"
register_type: read
value_type: U_WORD
accuracy_decimals: 0
filters:
- multiply: 0.1
address: 0x0103
offset: 0
register_type: read
value_type: U_WORD
filters:
- multiply: 1
name: "Redox ppm - setpoint"
address: 0x0508
offset: 0
register_type: read
value_type: U_WORD
filters:
- multiply: 1
Then I was able to read out all the values of the controller
Hope this helps anyone setting up their integration too !
sponnet
(Stefaan Ponnet)
September 16, 2022, 11:40pm
4
I used this schema to connect my RS485 module to the wemos D1 mini:
scOOb
(Robin Fiddelaers)
October 17, 2023, 9:24am
5
I’m certainly interested in this topic. Having an Oxilife myself and not willing to pay the 500+ EUR for an official Wifi-module, I’ll try to integrate the data into my HA Dashboard, maybe even to control it from HA in the future …
I 'll have to check, but I think I’ve got the necessary HW somewhere in a box.
But Modbus is completely new to me … So we’ll see where it gets me …
It’s an interesting project …
cnbe70
(Christian)
May 1, 2024, 9:22am
6
Hi Stefaan,
This is really really great and exactly what I was looking for! I will try that! Many thanks for sharing your experience.
Regards
Christian
cnbe70
(Christian)
May 4, 2024, 6:30pm
7
Hi Stefaan,
sorry to bother you with an issue I have. I made larger progess in soldering the pcbs and configure the software. Everyting works fine so far.
The only thing I am currently totall lost is how to connect the RS485 TTL Board to my Aquascenic device.
However I connect it. Either nothing happens or the Aquascenic shows an communication error.
I am not sure where to connect the two cables. Maybe you have a hint for me?
That would be fantastic.
Many thanks
Christian
substitutions:
friendly_name: Aquascenic
esphome:
friendly_name: ${friendly_name}
name_add_mac_suffix: false
project:
version: '1.0'
esp8266:
board: esp01_1m
# Enable logging
logger:
api:
# Allow Over-The-Air updates
ota:
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
# Set up a wifi access point
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
package_import_url: github://esphome/example-configs/esphome-web/esp8266.yaml@main
import_full_config: true
# To have a "next url" for improv serial
web_server:
port: 80
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 19200
stop_bits: 1
modbus:
modbus_controller:
address: 0x1
modbus_id: modbus1
setup_priority: -10
name: "Wasser Temperatur"
address: 0x0106
offset: 0
value_type: U_WORD
register_type: read
filters:
- multiply: 0.1
address: 0x0102
offset: 0
register_type: read
value_type: U_WORD
filters:
- multiply: 0.01
address: 0x0104
offset: 0
register_type: read
value_type: U_WORD
filters:
- multiply: 0.01
address: 0x0101
offset: 0
register_type: read
value_type: U_WORD
filters:
- multiply: 0.1
address: 0x0103
offset: 0
register_type: read
value_type: U_WORD
filters:
- multiply: 1
address: 0x0508
offset: 0
register_type: read
value_type: U_WORD
filters:
- multiply: 1
