I’m running home assistant supervised in my archlinux machine. To help others, I’ve created an AUR package. Check it out at AUR (en) - homeassistant-supervised
Any feedback is appreciated.
I love arch, a great system. But so long as everyone who uses this realises it will be unsupported. (except by you )
Sure, I get it. But my homeassistant machine is also my HTPC. And I had issues with some packages available on Debian. That is my least effort way of dealing with it.
I’ve just reversed engineered supervised installer and converted to arch pkg. Also, any help to maintain is appreciated.
I applaud it, and I am now subscribed to this thread, so will do what I can.
I subscribed to this thread too, as I will use the AUR installer in the next days.
Same setup here, HA is on my HTPC, and I need add-ons and all the fancy bells & whistles to get frigate full integration.
Thanks for your work.
That’s my first package. Any feedback is appreciated.
Hi, I build your HA supervised, I see it in system process but HA still not supervised.
Anyone try test it ?
What defines a supervised homeassistant? For me this shows as supervised:
Also acessing the observer into http://ip:4357/ :
Probably Unhealthy is because they have problem with connection to bluetooth.
I have HASS from official repository in pacman.
Have you configured AppArmor?
https://wiki.archlinux.org/title/AppArmor
You need to add this Kernel Parameters:
lsm=landlock,lockdown,yama,integrity,apparmor,bpf
And enable apparmor service: apparmor.service
Have you already enabled and started both services:
hassio-apparmor.service
and hassio-supervisor.service
Also run:
$ aa-enabled
And
# aa-status
I already had frigate installed as docker container, and tuned /etc/docker/daemon.json
for SHM upgrade. The AUR package complained the file is already present on the FS.
I backed it up away, installed homeassistant-supervised
and merged my setting manually.
I suggest a more flexible way of installation of the file, but I am not competent on Arch (yet). On debian I know there are a bunch of package maintainer script to merge configuration files and not ship them “barely” as normal package files.
I think there is the same thing on Arch but don’t know how it is called nor how it works.
Thanks for the feedback Karmak23. I’ll consider it in a future update.
Status od ArmArmor
[adi@STORKserver ~]$ aa-enabled
Yes
[adi@STORKserver ~]$ aa-status
apparmor module is loaded.
64 profiles are loaded.
64 profiles are in enforce mode.
/usr/lib/apache2/mpm-prefork/apache2
/usr/lib/apache2/mpm-prefork/apache2//DEFAULT_URI
/usr/lib/apache2/mpm-prefork/apache2//HANDLING_UNTRUSTED_INPUT
/usr/lib/apache2/mpm-prefork/apache2//phpsysinfo
apache2
apache2//phpsysinfo
avahi-daemon
dnsmasq
dnsmasq//libvirt_leaseshelper
docker-default
dovecot
dovecot-anvil
dovecot-auth
dovecot-config
dovecot-deliver
dovecot-dict
dovecot-director
dovecot-doveadm-server
dovecot-dovecot-auth
dovecot-dovecot-lda
dovecot-dovecot-lda//sendmail
dovecot-imap
dovecot-imap-login
dovecot-lmtp
dovecot-log
dovecot-managesieve
dovecot-managesieve-login
dovecot-pop3
dovecot-pop3-login
dovecot-replicator
dovecot-script-login
dovecot-ssl-params
dovecot-stats
hassio-supervisor
hassio-supervisor///usr/bin/gdbus
hassio-supervisor///usr/bin/git
identd
klogd
lsb_release
mdnsd
nmbd
nscd
ntpd
nvidia_modprobe
nvidia_modprobe//kmod
php-fpm
ping
samba-bgqd
samba-dcerpcd
samba-rpcd
samba-rpcd-classic
samba-rpcd-spoolss
smbd
smbldap-useradd
smbldap-useradd///etc/init.d/nscd
syslog-ng
syslogd
traceroute
winbindd
zgrep
zgrep//helper
zgrep//sed
0 profiles are in complain mode.
0 profiles are in kill mode.
0 profiles are in unconfined mode.
0 processes have profiles defined.
0 processes are in enforce mode.
0 processes are in complain mode.
0 processes are unconfined but have a profile defined.
0 processes are in mixed mode.
0 processes are in kill mode.
Just to let you know, as far as I configured it (and after having done all the apparmor
stuff you wrote), your supervised version works like a charm.
I’m currently looking for a “clean” way to bind-mount read-only the frigate host storage path, just for HA to display the remaining storage in my dashboard via the sensor.systemmonitor
. I already got /
, I want /home/data
Where is the “main” HA container configuration file ?
EDIT: I will start here : [Solved] Hassio and volume mount issues - #2 by febalci This doesn’t seem very clean because changes are not kept when container is updated, I have to redo the configuration. Is there any way to have a docker-compose.yml file somewhere ?
The files are located at: /usr/share/hassio/homeassistant/
. Just add a link inside that path and it’ll do the job. Remember to add the right permission to that folder.
For anyone landing here and seeing their supervisor reported as “Unhealthy” even after following all the installation steps listed in the Arch Wiki page, try this:
apparmor
service runninghomeassistant-supervised
AUR packageThis made my supervisor “Healthy” for a brief moment. Then I checked the supervisor logs:
docker logs -f hassio_supervisor
I noticed it was being flagged as “Unhealthy” due to running the watchtower
container on the same host. This seems to make the supervisor unhealthy. I assume an incorrectly configured watchtower
container could mess up with the running Hassio containers so they just flag it.
After stopping and removing watchtower
, it shows as “Healthy” and I can install add-ons as expected.
Rokam, I posted a comment on AUR with errors I found in the installer.
in my case the problem is probably in this:
22-09-24 00:14:27 ERROR (MainThread) [supervisor.host.network] Can't update config on eth0: ipv4.gateway: gateway is invalid
22-09-24 00:14:31 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/None-homeassistant with tag landingpage.
22-09-24 00:14:31 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/None-homeassistant:landingpage: 400 Client Error for http+docker://localhost/v1.41/images/create?tag=landingpage&fromImage=ghcr.io%2Fhome-assistant%2FNone-homeassistant&platform=linux%2Farm64: Bad Request ("invalid reference format: repository name must be lowercase")
22-09-24 00:14:31 WARNING (MainThread) [supervisor.homeassistant.core] Fails install landingpage, retry after 30sec
But I still don’t know how to fix it.
I don’t know yet where he gets the None-homeassistant address
