I purchased a while ago two of these boards ESP32 UNO PSRAM from Arducam. I finally got some time to work with them, I found the cam pinout from this forum post and wrote this yaml file:
esphome:
esp32:
board: esp32dev
framework:
type: arduino
logger:
api:
wifi:
ssid: !secret wifi_ssid
fast_connect : true
reboot_timeout: 120s
power_save_mode: none
ap:
ssid: "ESP32_ACam_01"
web_server:
port: 80
captive_portal:
ota:
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
# Image settings
max_framerate: 0.5 fps
resolution: 640x480
jpeg_quality: 10
contrast: 0
saturation: 0
brightness: 2
aec2: True
It works and I can get images but the quality is really bad. I get it is 2MP so I should not expect 8K quality, but it is really bad. I played with some of the values, but nothing made the image any better.
Has anyone used any of these or anything with the OV2640? If so, is there a way to improve the image quality?
