*hello
this temp ic is working with a esp8266 with arduino enviroment.
the esp8266 is working with wifi with an ip-adress
How do i get this data in Hassio?
I look for a SIMPLE demo
with that script for this configuration.yaml
After that can i look for using this data.
But if you don’t want to setup ESPHome (and the associated containers, etc. needed to compile it) then here is an example using MQTT I found by Googling:
There’s a pretty good description of how it works on the page.
