Arduino broken in 0.30.1
I was using the above config up until the recent upgrade to 0.30.1.
arduino:
  port: /dev/ttyACM0
switch:
  platform: arduino
  pins:
    11:
      type: digital
    12:
      type: digital
      default: on
      negate: true
    13:
      type: digital
After the upgrade, I got a message on the home screen (which was nice) to say that switch.arduino was broken.
After working through the log, I see the configuration was changed at https://home-assistant.io/components/switch.arduino/ but I did not see this mentioned under breaking changes in the recent blog post.
I’ve fixed this now but it may be worth letting folks know?
arduino:
  port: /dev/ttyACM0
switch:
  platform: arduino
  pins:
    11:
    12:
    13:
Thanks. Is now added the the “Breaking changes” section.
You’re welcome. Also removed my bit about the blank services page. See this has changed too.
