charly405
(Charly405)
March 28, 2024, 10:44am
1
I have an Arduino connected to my portafilter.
This receives data and makes it available to my mqtt. (MQTT is running and I have integrated many devices that work without problems).
For testing I then added the sensors in my configuration.yaml.
mqtt:
- name: "MaraX2 Steam Temperature"
state_topic: "MaraX2/MaraX2Data"
unique_id: "marax2_steam_temperature"
unit_of_measurement: "°C"
value_template: "{{ value_json.steam_temperature }}"
- name: "MaraX2 Target Steam Temperature"
unique_id: "marax2_target_steam_temperature"
value_template: "{{ value_json.target_steam_temperature }}"
These sensors work and
now I would like to use the autodiscover but that doesn’t work.
According to the serial log of the Arduino, the autodiscovery message is sent.
11:05:29.802 → WiFi verbunden
11:05:29.833 → IP-Adresse:
11:05:29.833 → 192.168.1.129
11:05:29.865 → Verbinde zu MQTT…verbunden
11:05:29.896 → Publishing discovery message:
11:05:29.929 → {“name”:“LelitMaraX2”,“state_topic”:“MaraX2/MaraX2Data”,“availability_topic”:“MaraX2/availability”,“payload_available”:“online”,“payload_not_available”:“offline”,“device”:{“identifiers”:“LelitMaraX2”,“name”:“Mara”,“model”:“MaraX2”,“manufacturer”:“Lelit”},“unique_id”:“MaraX2mqtt”}
but when I look in the MQTT Explorer I can’t find anything under “homeassistant/sensor/MaraX2/config”
This Topic does not exist: homeassistant/sensor/MaraX2
I think there is an error somewhere in the sketch.
Because I honestly use the help ChatGPT to add the MQTT. Which also worked but not the autodiscover.
Here my Arduino Code
Maybe someone has an idea what I am doing wrong.
Troon
(Troon)
March 28, 2024, 11:14am
2
Please format code properly for the forum .
idiot robot strikes again.
I think the problem is in the publish
call with the retain
flag set. That retain
flag is actually the fourth argument . Try this:
// Publish sensor discovery message
int len = strlen(jsonBuffer) + 1;
client.publish(mqtt_discovery_topic, jsonBuffer, len, true);
charly405
(Charly405)
March 28, 2024, 11:26am
3
when i change
client.publish(mqtt_discovery_topic, jsonBuffer, true);
to
i get an compile error message:
Users/itsmeMario/Downloads/mara_x_mqtt/mara_x_mqtt.ino: In function 'void publishDiscovery()':
/Users/itsmeMario/Downloads/mara_x_mqtt/mara_x_mqtt.ino:137:40: error: invalid conversion from 'char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
137 | client.publish(mqtt_discovery_topic, jsonBuffer, len, true);
| char*
In file included from /Users/itsmeMario/Downloads/mara_x_mqtt/mara_x_mqtt.ino:13:
Users/itsmeMario/Documents/Arduino/sketchbooks/libraries/PubSubClient/src/PubSubClient.h:154:55: note: initializing argument 2 of 'boolean PubSubClient::publish(const char*, const uint8_t*, unsigned int, boolean)'
154 | boolean publish(const char* topic, const uint8_t * payload, unsigned int plength, boolean retained);
exit status 1
Compilation error: invalid conversion from 'char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]```
Troon
(Troon)
March 28, 2024, 11:54am
4
Ah, ignore me then. I see there is a version of publish
in the client that should work with the original code:
boolean publish(const char* topic, const char* payload, boolean retained);
Sorry I can’t help further. My next step would be to move the debug printout after the publish line, and then try to see what that publish
function returns.
charly405
(Charly405)
March 28, 2024, 12:51pm
5
I have now done that.
It seems the code does not arrive at all in MQTT.
13:49:39.555 -> �D9KƜ�����
13:49:39.636 -> Verbinde mit WLAN...
13:49:40.268 -> ..........
13:49:45.497 -> WiFi verbunden
13:49:45.497 -> IP-Adresse:
13:49:45.528 -> 192.168.1.129
13:49:45.528 -> Verbinde zu MQTT...verbunden
13:49:45.560 -> Publishing discovery message:
13:49:45.592 -> {"name":"LelitMaraX2","state_topic":"MaraX2/MaraX2Data","availability_topic":"MaraX2/availability","payload_available":"online","payload_not_available":"offline","device":{"identifiers":"LelitMaraX2","name":"Mara","model":"MaraX2","manufacturer":"Lelit"},"unique_id":"MaraX2mqtt"}
13:49:45.881 -> Publishing discovery message result: 0
13:49:45.913 -> C123b,045,000,039,0000,0
francisp
(Francis)
March 28, 2024, 1:16pm
6
is 281 characters, the Arduino standard MQTT buffer is 255
here
you can find the supported abbreviations
charly405
(Charly405)
March 28, 2024, 2:05pm
7
I have shortened it to 224 characters but it still does not work.
14:58:56.990 -> Publishing discovery message:
14:58:57.022 -> {"name":"LelitMaraX2","stat_t":"MaraX2/MaraX2Data","avty_t":"MaraX2/availability","pl_avail":"online","pl_not_avail":"offline","device":{"ids":"LelitMaraX2","name":"Mara","mdl":"MaraX2","mf":"Lelit"},"unique_id":"MaraX2"}
14:58:57.248 -> Publishing discovery message result: 0
charly405
(Charly405)
March 29, 2024, 5:41pm
8
Does anyone else have any ideas?
