Arduino-Port-Expander Problem with Analog and Digital Inputs
I am using the Arduino Port Expander to get 8 Digital Outputs and 6 Analog Inputs.
esphome:
  includes:
    - arduino_port_expander.h
esp8266:
  board: d1_mini
wifi:
  ssid: !secret wifi_ssid
api:
ota:
# define i2c device
# for an ESP8266 SDA is D2 and goes to Arduino's A4
#                SCL is D1 and goes to Arduino's A5
i2c:
logger:
  level: DEBUG
# define the port expander hub, here we define one with id 'expander1',
# but you can define many
custom_component:
  - id: expander1
    lambda: |-
      auto expander = new ArduinoPortExpander(i2c_component, 0x08, true);
      return {expander};
# define binary outputs, here we have 4, as the relays are inverse logic
# (a path to ground turns the relay ON), we defined the inverted: true
# option of ESPHome outputs.
output:
- platform: custom
  type: binary
  lambda: |-
    return {ape_binary_output(expander1, 2),
            ape_binary_output(expander1, 3),
            ape_binary_output(expander1, 4),
            ape_binary_output(expander1, 5),
            ape_binary_output(expander1, 6),
            ape_binary_output(expander1, 7),
            ape_binary_output(expander1, 8),
            ape_binary_output(expander1, 9)};
  outputs:
    - id: relay_1
      inverted: true
    - id: relay_2
      inverted: true
    - id: relay_3
      inverted: true
    - id: relay_4
      inverted: true
    - id: relay_5
      inverted: true
    - id: relay_6
      inverted: true
    - id: relay_7
      inverted: true
    - id: relay_8
      inverted: true
switch:
  - platform: output
    output: relay_8
  - platform: output
    output: relay_7
  - platform: output
    output: relay_6
  - platform: output
    output: relay_5
  - platform: output
    output: relay_4
  - platform: output
    output: relay_3
  - platform: output
    output: relay_2
  - platform: output
    output: relay_1
# A4 and A5 reserved for i2c
# define analog sensors
  - platform: custom
    lambda: |-
      return {ape_analog_input(expander1, 0),
              ape_analog_input(expander1, 1),
              ape_analog_input(expander1, 2),
              ape_analog_input(expander1, 3),
              ape_analog_input(expander1, 6),
              ape_analog_input(expander1, 7)};
    sensors:
      - name: "A0 Rasen vor Pool"
        unit_of_measurement: "%"
        device_class: humidity
        state_class: measurement
        accuracy_decimals: 0
        filters:
        - throttle: 10s
        - median:
            window_size: 60
            send_every: 10
            send_first_at: 1
        - lambda: return x * (5.0 / 1023.0);
        - calibrate_linear:
            - 0.95 -> 100
            - 2.5 -> 0
        - lambda: |
            if (x < 0) return 0;
            else if (x > 100) return 100;
            else return (x);
      - name: "A1 Rasen vor Pool"
        filters:
        - throttle: 10s
        - median:
            window_size: 60
            send_every: 10
            send_first_at: 1
        - calibrate_linear:
            - 0.95 -> 100
            - 2.5 -> 0
        - lambda: |
            else return (x);
      - name: "A2 Rasen vor Pool"
        filters:
        - throttle: 10s
        - median:
            window_size: 60
            send_every: 10
            send_first_at: 1
        - calibrate_linear:
            - 0.95 -> 100
            - 2.5 -> 0
        - lambda: |
            else return (x);
      - name: "A3 Rasen vor Pool"
        filters:
        - throttle: 10s
        - median:
            window_size: 60
            send_every: 10
            send_first_at: 1
        - calibrate_linear:
            - 0.95 -> 100
            - 2.5 -> 0
        - lambda: |
            else return (x);
      - name: "A4 Rasen vor Pool"
        filters:
        - throttle: 10s
        - median:
            window_size: 60
            send_every: 10
            send_first_at: 1
        - calibrate_linear:
            - 0.95 -> 100
            - 2.5 -> 0
        - lambda: |
            else return (x);
      - name: "A5 Rasen vor Pool"
        filters:
        - throttle: 10s
        - median:
            window_size: 60
            send_every: 10
            send_first_at: 1
        - calibrate_linear:
            - 0.95 -> 100
            - 2.5 -> 0
        - lambda: |
            else return (x);
Problem is, that after I activate the Analog Input Section, the Relais 3,4,7,8 are not working. If I comment out the Analog Sensor part, all 8 Relais are working fine.
I am using
D2 โ†’ D9 for the Relays
A0, A1, A2, A3, A6, A7 for the Analog Input
I have found new Informations.
If Relay is off, the Digital Out of the Arduino does have 5V โ†’ correct.
If Relay is on, the Digital Out of the Arduino does have 0V โ†’ correct.
If Relay is no the same Number, as the Analog Sensor (A3 And D3) and is on, the Digital Out of the Arduino does have ~ 3V โ†’ not correct.
Have found a workaround for my Problem: arduino_port_expander.h ยท GitHub
