Okay, so here is my issue. Not sure where to place this in categories.
I have made a lighting detection module from an arduino. (I will place code at the end). I fot all the information from this web site. https://github.com/klauscam/Arduino-Lightning-Detector. It reads out to a serial monitor.
So here is my problem. I can get it to read once or maybe twice. but I keep getting aio errors. There so bad that it crashes home assistant. I remove arduino serial and it starts working again. Is there something special I need to do? I would really like for this to work. If the internet goes out. I can still know if the lighting is close and I can have the software that the correct actions. Is there something I need to change in this code?
Thanks,
#define FASTADC 1
// defines for setting and clearing register bits
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
int data = 512;
int storage[512];
long batchStarted;
long batchEnded;
int reading;
int count;
int maximum;
int minimum;
bool toSend;
void setup() {
#if FASTADC
// set prescale to 16
sbi(ADCSRA,ADPS2) ;
cbi(ADCSRA,ADPS1) ;
cbi(ADCSRA,ADPS0) ;
#endif
// put your setup code here, to run once:
Serial.begin(115200);
pinMode(A4,INPUT);
Serial.println(micros());
batchStarted=0;
batchEnded=0;
reading=0;
count=0;
maximum=0;
minimum=1023;
toSend=false;
void loop() {
// put your main code here, to run repeatedly:
reading = (analogRead(A4));
storage[count]=reading;
if ((!toSend)&&(count!=0)&&((reading>storage[count-1]+10)||(reading<storage[count-1]-10))){
toSend=true;
count=count+1;
if ((count == 512) && (toSend))
count=0;
batchEnded = millis();
sendData();
batchStarted = millis();
else if (count==512){
count=0;
//sendData();
void sendData()
//Serial.print(">>>");
//Serial.println(batchStarted);
for (int i=0;i<data;i++){
Serial.println(storage[i]);
//Serial.print("<<<");
//Serial.println(batchEnded);
//Serial.println("END");
toSend=false;
