Hi Everyone,
Thank for readin my post. I’m using a knock-off board with Arduino Mega R3 Wifi
this board had ESP8266 on the board. https://Arduino Mega R3 - AliExpress Link
The ESP sometimes works and other times doesn’t. when I add more HASwitches it just keep looping like below and doen’t accept commands from Home Assistant.
and when I add only one or two switches and activate the switches on=>Off=>On…
within a few clicks the ESP will drop the connection to MQTT or to the Wifi and resets. this is fursterating as I can’t figure what is wrong… is it a memory leak issue or something in the WiFiEsp or ArduinoHA libraries… I don’t know.
The below code works somehow stable when I have only two HASwitch only, when I add HASelect and change the value in Home Assistant, I get [WiFiEsp] Timeout.
The code is not cleaned and just for testing but I wanted to track where is the issue.
#include <ArduinoHA.h>
#include <WiFiEsp.h>
#include "prvWifiMQTTSetup.h" // Wifi and MQTT credentials
// Digital Output
int st_Led = 13;
int Buzzer = 49;
int LED1 = 42;
int LED2 = 43;
int LED3 = 44;
int LED4 = 45;
int LED5 = 46;
int Relay1 = 47;
int Relay2 = 48;
// LCD & Keypad
#include <LiquidCrystal.h>
int BackLight = 53;
int COL1 = 33;
int COL2 = 32;
int COL3 = 31;
int COL4 = 30;
int ROW1 = 37;
int ROW2 = 36;
int ROW3 = 35;
int ROW4 = 34;
int W_MBR = A0;
int W_FR = A1;
int W_Ktcn = A2;
int W_DR = A3;
int W_GBR = A4;
int W_Str = A5;
int W_GR = A6;
int D_F = 18;
int D_B = 19;
int D_G = 20;
LiquidCrystal lcd(41, 40, 22, 23, 24, 25, 26, 27, 28, 29);
unsigned char Switch;
int status = WL_IDLE_STATUS;
#define AlarmTopic "/homeassistant/HouseAlarm"
#define AlarmTopicStatus "/homeassistant/HouseAlarm/Replies"
#define nMin 0
#define nMax 100
void sBuzz(unsigned int time, unsigned int count, unsigned int silent );
void reconnect();
unsigned char ScanKeys();
unsigned long lastReadAt = millis();
void onConnected();
void onSwitchCommand(bool state, HASwitch* sender);
void onMessage(const char* topic, const uint8_t* payload, uint16_t length);
void onSelectCommand(int8_t index, HASelect* sender);
void onNumberCommand(HANumeric number, HANumber* sender);
WiFiEspClient wifiClient;
/// Must Define the device then HAMqtt then the sensors and switches
HADevice device("XAlarm");
byte mac[] = {0x00, 0x10, 0xFA, 0x6E, 0x38, 0x4A};
HAMqtt mqtt(wifiClient, device);
HASwitch Switch1("Switch1");
HASwitch Switch2("Switch2");
HASelect Dropdown1("Alarm Mode");
HANumber Numeric1("myNumber", HANumber::PrecisionP1);
HABinarySensor Win_MB("Window1");
HABinarySensor Win_FR("Window2");
HABinarySensor Win_Ktc("Window3");
HABinarySensor Win_GBR("Window4");
HABinarySensor Win_DR("Window5");
HABinarySensor Win_Str("Window6");
HABinarySensor Win_GR("Window7");
HABinarySensor Door_F("Door1");
HABinarySensor Door_B("Door2");
HABinarySensor Door_G("Door3");
void setup()
// Digital Output
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);
pinMode(LED5, OUTPUT);
pinMode(Relay1, OUTPUT);
pinMode(Relay2, OUTPUT);
pinMode(Buzzer, OUTPUT);
pinMode(st_Led, OUTPUT);
// LCD & Keypad
lcd.begin(16, 2);
pinMode(BackLight, OUTPUT);
pinMode(COL1, INPUT);
pinMode(COL2, INPUT);
pinMode(COL3, INPUT);
pinMode(COL4, INPUT);
pinMode(ROW1, OUTPUT);
pinMode(ROW2, OUTPUT);
pinMode(ROW3, OUTPUT);
pinMode(ROW4, OUTPUT);
pinMode( W_MBR, INPUT_PULLUP);
pinMode( W_FR, INPUT_PULLUP);
pinMode( W_Ktcn, INPUT_PULLUP);
pinMode( W_DR, INPUT_PULLUP);
pinMode( W_GBR, INPUT_PULLUP);
pinMode( W_Str, INPUT_PULLUP);
pinMode( W_GR, INPUT_PULLUP);
pinMode( D_F, INPUT_PULLUP);
pinMode( D_B, INPUT_PULLUP);
pinMode( D_G, INPUT_PULLUP);
int key = 0 ;
lcd.home();
lcd.print(" --[ Test ]-- ");
digitalWrite(BackLight, HIGH);
// initialize serial for debugging
Serial.begin(115200);
// initialize serial for ESP module
Serial3.begin(115200);
// initialize ESP module
WiFi.init(&Serial3);
while ( status != WL_CONNECTED)
sBuzz(200, 1, 1);
Serial.print("Attempting to connect to SSID: ");
// don't continue
Serial.println(ssid);
lcd.clear();
lcd.print ("Retry " + String(ssid));
// lcd.autoscroll();
// lcd.noAutoscroll();
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
if (status == 1) lcd.clear(); lcd.print (" Connected "); sBuzz(200, 3,1);
// wait 10 seconds for connection:
Serial.print(".");
delay(1000);
status = WiFi.status();
Serial.println("Connected to the network===>>>");
Serial.print(status);
Serial.println("IP Address: ");
Serial.println(WiFi.localIP());
// set device's details (optional)
device.setName("AlarmSystem");
device.setSoftwareVersion("0.0.1");
device.setManufacturer("ZeCorp.");
device.setModel("000-123");
// Set the Name and Icons for the sensors/switches in the Device
Switch1.setIcon("mdi:toggle-switch-outline");
Switch1.setName("Siren");
Switch1.setRetain(true);
Switch1.onCommand(onSwitchCommand);
Switch2.setIcon("mdi:toggle-switch-outline");
Switch2.setName("Switch 2");
Switch2.setRetain(true);
Switch2.onCommand(onSwitchCommand);
Dropdown1.setOptions("DisArm;Night;Arm"); // use semicolons as separator of options
Dropdown1.onCommand(onSelectCommand);
Dropdown1.setIcon("mdi:home"); // optional
Dropdown1.setName("Mode"); // optional
Numeric1.onCommand(onNumberCommand);
// Optional configuration
Numeric1.setIcon("mdi:home");
Numeric1.setName("Desk Height");
Numeric1.setMin(nMin); // can be float if precision is set via the constructor
Numeric1.setMax(nMax); // can be float if precision is set via the constructor
Numeric1.setStep(1); // minimum step: 0.001f
Numeric1.setUnitOfMeasurement("cm");
// Numeric1.setMode(HANumber::ModeBox);
Numeric1.setMode(HANumber::ModeSlider);
// You can set retain flag for the HA commands
Numeric1.setRetain(true);
// optional properties
Win_MB.setCurrentState(digitalRead(W_MBR));
Win_MB.setName("Windows: Bed Room");
Win_MB.setDeviceClass("window");
Win_MB.setIcon("mdi:window-closed-variant");
Win_FR.setCurrentState(digitalRead(W_FR));
Win_FR.setName("Windows: Family Room");
Win_FR.setDeviceClass("window");
Win_FR.setIcon("mdi:window-closed-variant");
Win_Ktc.setCurrentState(digitalRead(W_Ktcn));
Win_Ktc.setName("Windows: Kitchen");
Win_Ktc.setDeviceClass("window");
Win_Ktc.setIcon("mdi:window-closed-variant");
Win_GBR.setCurrentState(digitalRead(W_GBR));
Win_GBR.setName("Windows: Guest Bathroom");
Win_GBR.setDeviceClass("window");
Win_GBR.setIcon("mdi:window-closed-variant");
Win_DR.setCurrentState(digitalRead(W_DR));
Win_DR.setName("Windows: Dinning Room");
Win_DR.setDeviceClass("window");
Win_DR.setIcon("mdi:window-closed-variant");
Win_Str.setCurrentState(digitalRead(W_Str));
Win_Str.setName("Windows: Stairs");
Win_Str.setDeviceClass("window");
Win_Str.setIcon("mdi:window-closed-variant");
Win_GR.setCurrentState(digitalRead(W_GR));
Win_GR.setName("Windows: Game Room");
Win_GR.setDeviceClass("window");
Win_GR.setIcon("mdi:window-closed-variant");
Door_F.setCurrentState(digitalRead(D_F));
Door_F.setName("Door: Front");
Door_F.setDeviceClass("door");
Door_F.setIcon("mdi:door");
Door_B.setCurrentState(digitalRead(D_B));
Door_B.setName("Door: Back");
Door_B.setDeviceClass("door");
Door_B.setIcon("mdi:door");
Door_G.setCurrentState(digitalRead(D_G));
Door_G.setName("Door: Garage");
Door_G.setDeviceClass("door");
Door_G.setIcon("mdi:door");
// MQTT Setup
sBuzz(2000,1,1);
mqtt.begin(MQTT_SERVER, BROKER_USERNAME, BROKER_PASSWORD);
// mqtt.setDiscoveryPrefix("homeassistant");
// mqtt.setDataPrefix("aha");
// mqtt.onMessage(onMessage);
mqtt.onConnected(onConnected);
void loop() {
sBuzz(10,5,1);
mqtt.loop();
void sBuzz(unsigned int time, unsigned int count, unsigned int Sound )
for (int i = 0; i < count; i++) {
digitalWrite(st_Led, HIGH);
if (Sound > 0)
digitalWrite(Buzzer, HIGH);
delay(time);
digitalWrite(st_Led, LOW);
digitalWrite(Buzzer, LOW);
delay(100);
void reconnect()
// Loop until we're reconnected
sBuzz(3000, 3, 1);
// while (!wifiClient.connected())
// Serial.print("Attempting MQTT connection...");
// // Attempt to connect
// if (wifiClient.connect(MQTT_SERVER, BROKER_USERNAME, BROKER_PASSWORD))
// Serial.println("Connected to Home Assistant");
// // Once connected, publish an announcement...
// mqtt.subscribe(AlarmTopic);
// else
// Serial.print("failed, rc=");
// Serial.print(wifiClient.state());
// Serial.println(" try again in 5 seconds");
// // Wait 5 seconds before retrying
// delay(100);
// Serial.println("MQTT command recieved.");
if (sender == &Switch1) {
// the switch1 has been toggled
// state == true means ON state
digitalWrite(Relay1, (state ? HIGH : LOW));
Serial.println("Relay1 = " + String((state ? HIGH : LOW)));
} else if (sender == &Switch2) {
// the switch2 has been toggled
digitalWrite(Relay2, (state ? HIGH : LOW));
Serial.println("Relay 2 = " + String((state ? HIGH : LOW)));
sBuzz(200, 2, 1);
sender->setState(state); // report state back to the Home Assistant
// float output;
// char buffer[32];
// Serial.println("MQTT message recieved on topic: ");
// Serial.println(topic);
// Serial.print("Data: ");
// Serial.println((const char*)payload);
// checkmessage(payload);
// callback (topic, payload, length);
Serial.println("onSelectCommand");
switch (index)
case 0:
// Option "Low" was selected
// digitalWrite(Relay1, HIGH);
// Serial.println("onSelectCommand = case 0");
break;
case 1:
// Option "Medium" was selected
// digitalWrite(Relay1, LOW);
// Serial.println("onSelectCommand = case 1");
break;
case 2:
// Option "High" was selected
// digitalWrite(Relay2, HIGH);
// Serial.println("onSelectCommand = case 2");
break;
case 3:
// digitalWrite(Relay2, LOW);
// Serial.println("onSelectCommand = case 3");
default:
Serial.println("onSelectCommand = default");
// unknown option
return;
sender->setState(index); // report the selected option back to the HA panel
if (sender->getCurrentOption()) {
Serial.print("Current option: ");
Serial.println(sender->getCurrentOption());
void onConnected()
Serial.println("MQTT connection established.");
mqtt.publish(AlarmTopicStatus, "Connected");
// Switch1.setAvailability(true);
// Switch2.setAvailability(true);
sBuzz(50,3,1);
if (!number.isSet()) {
// the reset command was send by Home Assistant
number.setBaseValue(50);
} else {
// you can do whatever you want with the number as follows:
int8_t numberInt8 = number.toInt8();
int16_t numberInt16 = number.toInt16();
int32_t numberInt32 = number.toInt32();
uint8_t numberUInt8 = number.toUInt8();
uint16_t numberUInt16 = number.toUInt16();
uint32_t numberUInt32 = number.toUInt32();
float numberFloat = number.toFloat();
Serial.println("Number Selected=" + String(numberInt16));
if (numberInt16 >=200){digitalWrite(LED1, HIGH);}
if (numberInt16 >=350){digitalWrite(LED2, HIGH);}
if (numberInt16 >=450){digitalWrite(LED3, HIGH);}
if (numberInt16 >=600){digitalWrite(LED4, HIGH);}
if (numberInt16 >=900){digitalWrite(LED5, HIGH);}
if (numberInt16 < 200){digitalWrite(LED1, LOW);}
if (numberInt16 <350){digitalWrite(LED2, LOW);}
if (numberInt16 <450){digitalWrite(LED3, LOW);}
if (numberInt16 <600){digitalWrite(LED4, LOW);}
if (numberInt16 <900){digitalWrite(LED5, LOW);}
sender->setState(number); // report the selected option back to the HA panel
This is what is I’m receiving on the Serial port
[WiFiEsp] Initializing ESP module
[WiFiEsp] Initilization successful - 1.5.4
Attempting to connect to SSID: MySSID
[WiFiEsp] Connected to MySSID
.Connected to the network===>>>
1IP Address:
192.168.68.22
[WiFiEsp] Connecting to 192.168.68.88
[WiFiEsp] Disconnecting 3
[WiFiEsp] >>> TIMEOUT >>>
[WiFiEsp] Data packet send error (2)
[WiFiEsp] Failed to write to socket 3
