ArduinoJson v5 or v6?
I keep getting errors when trying this code: Generic Custom Component — ESPHome
Nevertheless, all works great if I comment the json related lines (functions subscribe_json and publish_json).
The file platformio.ini auto generated by esphome have this dependency: bblanchon/[email protected]
I wonder if the code above is still expecting ArduinoJson v5 instead of the current ArduinoJson v6!
Can anyone please confirm this or suggest a way to solve the problem?
PS - Here are the compilation errors:
In file included from src\main.cpp:34:0:
src\my_custom_component.h: In member function 'virtual void MyCustomComponent::setup()':
src\my_custom_component.h:13:73: error: no matching function for call to 'MyCustomComponent::subscribe_json(const char [15], void
(MyCustomComponent::*)(ArduinoJson::JsonObject&))'
     subscribe_json("the/json/topic", &MyCustomComponent::on_json_message);
In file included from src\esphome.h:30:0,
                 from src\main.cpp:3:
src\esphome\components\mqtt\custom_mqtt_device.h:96:8: note: candidate: template<class T> void esphome::mqtt::CustomMQTTDevice::subscribe_json(const string&, void (T::*)(const string&, ArduinoJson::JsonObject), uint8_t)
   void subscribe_json(const std::string &topic, void (T::*callback)(const std::string &, JsonObject), uint8_t qos = 0);
src\esphome\components\mqtt\custom_mqtt_device.h:96:8: note:   template argument deduction/substitution failed:
src\my_custom_component.h:13:73: note:   mismatched types 'const string& {aka const std::__cxx11::basic_string<char>&}' and 'ArduinoJson::JsonObject& {aka ArduinoJson6185_D1::ObjectRef&}'
src\esphome\components\mqtt\custom_mqtt_device.h:98:29: note: candidate: template<class T> void esphome::mqtt::CustomMQTTDevice::subscribe_json(const string&, void (T::*)(ArduinoJson::JsonObject), uint8_t)
   template<typename T> void subscribe_json(const std::string &topic, void (T::*callback)(JsonObject), uint8_t qos = 0);
src\esphome\components\mqtt\custom_mqtt_device.h:98:29: note:   template argument deduction/substitution failed:
src\my_custom_component.h:13:73: note:   mismatched types 'ArduinoJson::JsonObject {aka ArduinoJson6185_D1::ObjectRef}' and 'ArduinoJson::JsonObject& {aka ArduinoJson6185_D1::ObjectRef&}'
src\my_custom_component.h: In member function 'void MyCustomComponent::on_json_message(ArduinoJson::JsonObject&)':
src\my_custom_component.h:34:6: error: no matching function for call to 'MyCustomComponent::publish_json(const char [21], MyCustomComponent::on_json_message(ArduinoJson::JsonObject&)::<lambda(ArduinoJson::JsonObject&)>)'
src\esphome\components\mqtt\custom_mqtt_device.h:167:8: note: candidate: bool esphome::mqtt::CustomMQTTDevice::publish_json(const
string&, const json_build_t&, uint8_t, bool)
   bool publish_json(const std::string &topic, const json::json_build_t &f, uint8_t qos, bool retain);
src\esphome\components\mqtt\custom_mqtt_device.h:167:8: note:   candidate expects 4 arguments, 2 provided
src\esphome\components\mqtt\custom_mqtt_device.h:184:8: note: candidate: bool esphome::mqtt::CustomMQTTDevice::publish_json(const
string&, const json_build_t&)
   bool publish_json(const std::string &topic, const json::json_build_t &f);
src\esphome\components\mqtt\custom_mqtt_device.h:184:8: note:   no known conversion for argument 2 from 'MyCustomComponent::on_json_message(ArduinoJson::JsonObject&)::<lambda(ArduinoJson::JsonObject&)>' to 'const json_build_t& {aka const std::function<void(ArduinoJson6185_D1::ObjectRef)>&}'
No one?
Or everybody compiles Generic Custom Component — ESPHome without errors?
I do not doubt that at the time of its creation no compilations errors occur, but maybe with time and new library versions, the code is not functioning anymore (the json part of it).
Regards
Well, its seems that the current example is indeed wrong (at least with the current ArduinoJson library)!
Here is the corrections that must be made to be able to use JSON MQTT messages:
// The original code:
//void on_json_message(JsonObject &root)
// must be changed to this:
  void on_json_message(JsonObject root)
    if (!root.containsKey("key"))
      return;
    int value = root["key"];
    // do something with Json Object
    // publish JSON using lambda syntax
//  publish_json("the/other/json/topic", [=](JsonObject &root2)
    publish_json("the/other/json/topic", [=](JsonObject root2)
      { root2["key"] = "Hello World"; });
That is, in both cases the & must be removed!
As I suspected this is something related with the migration of ArduinoJson from v5 to v6!
