It’s possible to turn_off light in an area in HA, but it doesn’t seem to be doable in Node-Red yet?
You can create a group in Home Assistant and turn it on or off in Node Red using a Call Service Node. I just did this today to turn all lights on or off from Alexa.
The delays are probably not necessary, but some of the downstairs lights wouldn’t respond without a delay.
[{“id”:“843213c8.3155a”,“type”:“alexa-local”,“z”:“eb64de9a.f978e”,“devicename”:“All Lights”,“inputtrigger”:false,“x”:140,“y”:800,“wires”:[[“a39f6780b785b835”]]},{“id”:“d6bff3bc8c0eeb43”,“type”:“api-call-service”,“z”:“eb64de9a.f978e”,“name”:“All Upstairs Lights ON”,“server”:“cc0d1734.6963a8”,“version”:5,“debugenabled”:false,“domain”:“homeassistant”,“service”:“turn_on”,“areaId”:[],“deviceId”:[],“entityId”:[“group.upstairs”],“data”:"",“dataType”:“jsonata”,“mergeContext”:"",“mustacheAltTags”:false,“outputProperties”:[],“queue”:“none”,“x”:600,“y”:720,“wires”:[[]]},{“id”:“06b4b3ce5f121b28”,“type”:“api-call-service”,“z”:“eb64de9a.f978e”,“name”:“All Downstairs Lights ON”,“server”:“cc0d1734.6963a8”,“version”:5,“debugenabled”:false,“domain”:“homeassistant”,“service”:“turn_on”,“areaId”:[],“deviceId”:[],“entityId”:[“group.downstairs”],“data”:"",“dataType”:“jsonata”,“mergeContext”:"",“mustacheAltTags”:false,“outputProperties”:[],“queue”:“none”,“x”:750,“y”:760,“wires”:[[]]},{“id”:“6148c8bc62940e65”,“type”:“delay”,“z”:“eb64de9a.f978e”,“name”:"",“pauseType”:“delay”,“timeout”:“2”,“timeoutUnits”:“seconds”,“rate”:“1”,“nbRateUnits”:“1”,“rateUnits”:“second”,“randomFirst”:“1”,“randomLast”:“5”,“randomUnits”:“seconds”,“drop”:false,“allowrate”:false,“outputs”:1,“x”:560,“y”:760,“wires”:[[“06b4b3ce5f121b28”]]},{“id”:“a39f6780b785b835”,“type”:“switch”,“z”:“eb64de9a.f978e”,“name”:“ON or OFF”,“property”:“payload”,“propertyType”:“msg”,“rules”:[{“t”:“eq”,“v”:“on”,“vt”:“str”},{“t”:“eq”,“v”:“off”,“vt”:“str”}],“checkall”:“true”,“repair”:false,“outputs”:2,“x”:330,“y”:800,“wires”:[[“d6bff3bc8c0eeb43”,“6148c8bc62940e65”],[“e6990a94c11b1fdc”,“885621010560a48f”]]},{“id”:“e6990a94c11b1fdc”,“type”:“api-call-service”,“z”:“eb64de9a.f978e”,“name”:“All Upstairs Lights OFF”,“server”:“cc0d1734.6963a8”,“version”:5,“debugenabled”:false,“domain”:“homeassistant”,“service”:“turn_off”,“areaId”:[],“deviceId”:[],“entityId”:[“group.upstairs”],“data”:"",“dataType”:“jsonata”,“mergeContext”:"",“mustacheAltTags”:false,“outputProperties”:[],“queue”:“none”,“x”:610,“y”:880,“wires”:[[]]},{“id”:“1f66a37c5165c1d8”,“type”:“api-call-service”,“z”:“eb64de9a.f978e”,“name”:“All Downstairs Lights OFF”,“server”:“cc0d1734.6963a8”,“version”:5,“debugenabled”:false,“domain”:“homeassistant”,“service”:“turn_off”,“areaId”:[],“deviceId”:[],“entityId”:[“group.downstairs”],“data”:"",“dataType”:“jsonata”,“mergeContext”:"",“mustacheAltTags”:false,“outputProperties”:[],“queue”:“none”,“x”:750,“y”:920,“wires”:[[]]},{“id”:“885621010560a48f”,“type”:“delay”,“z”:“eb64de9a.f978e”,“name”:"",“pauseType”:“delay”,“timeout”:“2”,“timeoutUnits”:“seconds”,“rate”:“1”,“nbRateUnits”:“1”,“rateUnits”:“second”,“randomFirst”:“1”,“randomLast”:“5”,“randomUnits”:“seconds”,“drop”:false,“allowrate”:false,“outputs”:1,“x”:560,“y”:920,“wires”:[[“1f66a37c5165c1d8”]]},{“id”:“cc0d1734.6963a8”,“type”:“server”,“name”:“Home Assistant- Raspberry”,“version”:2,“addon”:true,“rejectUnauthorizedCerts”:true,“ha_boolean”:“y|yes|true|on|home|open”,“connectionDelay”:true,“cacheJson”:true,“heartbeat”:false,“heartbeatInterval”:30}]
Yes, I know, I’ve currently created light groups, but it would be nice to have the area in node-red as well.
The call-service node has an area field.
And, it works!
Huh? I don’t see that in my call-service node? Is that a stand-alone NR, or the HA addon?
Sounds like you need to update the HA nodes.
You are absolutely right, I had completely forgotten about that part, so it IS there, GREAT!
Hi guys,
Does anyone know how to get the AREA from the device_id in Node Red?
I’m using inovelli switches, and I would like 2X up/down to toggle the lights in the area that they are triggered from. For example, if I want to turn all the lights on in the kitchen, I should be able to go to any switch in the kitchen, and 2x click on it. I don’t want to create a flow for each area and each switch.
In node red, when you’re listening for z-wave events, you can capture the device_id and node_id from a switch that has been tapped. I would like to use that information to get the area, so that the area can be toggled.
Strangely, this template works:
{{ area_id('5897334658b0719fcfa8d7a9fc203e88')}}
But this doesn’t:
{{ area_id('{{msg.payload.event.device_id}}')}}
Thoughts?
I don’t use node red and this isn’t quite what you’re looking for but, since you’re not getting any other responses, you might check out: Control LEDs and LED Effects on Inovelli Dimmers, Switches, and Combo Fan / Lights by Area, Device, or Entity
Thank you, Kevin. There may be a script in that link that will move me closer to what I’m looking for. I appreciate it.
This thread helped me:
Thanks, jellelle. I haven’t been successful in getting this little flow to work. I’m assuming the ‘xxxx’ needs to be replace with the payload, but I can’t get it working. Have you got it working?
Yes, I found the area using that thread
"id": "232b60081f1e2976",
"type": "function",
"z": "d38e7ee93b0ccd72",
"name": "function 4",
"func": "var smokeDetectorId = \"binary_sensor.fibaro_fgsd002_006_smoke_detected\";\nvar template = \"{{area_id('\" + smokeDetectorId + \"')}}\";\n\nmsg.template = template;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 520,
"y": 1060,
"wires": [
"9252d41859fee091"
"id": "9252d41859fee091",
"type": "api-render-template",
"name": "",
"server": "2787f8eb66ddfc4a",
"version": 0,
"template": "",
"resultsLocation": "payload",
"resultsLocationType": "msg",
"templateLocation": "template",
"templateLocationType": "msg",
"x": 680,
"y": 1060,
"wires": [
"47a5496ed151ee4f"
"id": "47a5496ed151ee4f",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 830,
"y": 1060,
"wires": []
"id": "7b8303b99e0f7998",
"type": "inject",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 360,
"y": 1060,
"wires": [
"232b60081f1e2976"
"id": "2787f8eb66ddfc4a",
"type": "server",
"name": "Home Assistant",
"version": 5,
"addon": false,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": "30",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": ": ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "default",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": false
