Hi… really like where this has gone - loads of great effort. However, like a few folk on here, I can’t get it working under Hassio. I’ve had it working under Hassbian, but have done an install now on Hassio. It seems like the Meross-iot library doesn’t load; everything else seems to be in place, but the process of loading via the manifest.json file isn’t working. I’d guess it’s nothing specific to any of the libraries here though.
I went back to using Home Assistant proper from this - reformatted the SD card on the 'Pi, and it’s worked pretty much alright since. I’ve added a number of Meross components and they work first time - right from including via their app, into HA with no need to reconfigure, and even via Homebridge into Apple Home. I’m now controlling them via the Eve app and it works alright. (Not to take anything away from HA & the work done on this thread - it’s made things work really well. Thanks!)
Yes it is. However someone has reported that the new hardware revision of the MSS425E does not show as expected on HomeAssistant. Anyways, I’ve updated the library lately, do you mind upgrading to the last version and let me know if the problem still persists?
Hey folks
I wonder if you could help out a noob.
The custom Meross integration was working perfectly until I updated to the latest version of Hassio - and I’m now just seeing " Entity not available" on all of my Meross devices.
Any idea what I might need to do?
Hey thank you very much for the great work. I have few Meross Dimmers. I just need to know if I get these dimmers as switches or as lights, so I can not only turn on/off but dim them also.
Thanks again!
Ciao ragazzi ho un meross mss310 integrato in home assistant , mi calcola su ha solo i W e io avrei bisogno di avere il calcolo in kwh come sono sull’app.
come e possibile farlo ?
Hi. This morning I saw version 20200206.1 available on HACS.
After upgrading, my mss435 plugs became unavailable.
I reverted to 20200109.5 and everything is workin again.
I’m on Hassio 0.105.2.
But I have one question: All the integrations/components are communicating with the Meross Cloud API, am I right? So there is no solution to get a Meross device working without the Meross cloud service? As I read in the “Internet” since firmware v2 the direct access to Meross devices is no more possible.
