Are script variables available to populate a sensor?
Self explanatory title?
If I have several scripts all passing the same variables between them, is it possible to simply have script 1 somehow populate a sensor with all the variables as attributes?
The benefit of this would be a lot less code needs to be typed so making everything easier to read/maintain.
Hi @klogg
I haven’t tried this mayself but this may be of use:
https://community.home-assistant.io/t/trigger-based-template-sensor-to-store-global-variables/735474
Hi.
Nor have I but I am certainly loking at it now!!
Thank you!!
It works a treat!
