TL;DR - I am unable to restore snapshots made with version newer than 0.109.2. How to fix snapshots to a) containt secrects.yaml and b) restore all settings?
Long story:
I had sd card failure on my rasppberry pi 4 with hassos. Luckily backups were made to google drive so I decided to upgrade to more reliable NUC setup with ubuntu and (soon to be deprecated/or not) docker. But trying to restore backup failed. No error messages displayed. Just extensions restored but no config files, no dashboards, no users, no manual integrations. I tried “restore” and “wipe and restore” with no better results. Eventually I decided to do a clean install and transfer all configurations one by one manually. I downloaded “Full Snapshot 2020-06-06 17_35_58.tar”, unarchived it, then unarchived “homeassistant.tar.gz” and found out that secrets.yaml is missing. Then I started checking all backups one by one date back to “Full Snapshot 2020-06-01 17/35/48.tar” - 06.01 was created using “0.109.2” … and to my surprise 06.01 backup contained secrets.yaml. Then I tried to restore this 06.01 backup and GREAT SUCCESS! Everything restored correctly - users, ssl, all addons and dashboards.
I presume something is broken with snapshot function. I also tried to do snapshot on NUC after restore and updating to 0.110.6 and secrets.yaml is still missing.
Snapshot json THAT WORKED
  "slug": "47985b54",
  "name": "Full Snapshot 2020-06-01 17:35:48",
  "date": "2020-06-01T14:35:49.954271+00:00",
  "type": "full",
  "addons": [
      "slug": "core_check_config",
      "name": "Check Home Assistant configuration",
      "version": "3.3.0",
      "size": 0.0
      "slug": "core_dnsmasq",
      "name": "Dnsmasq",
      "version": "1.3",
      "size": 0.0
      "slug": "a0d7b954_nodered",
      "name": "Node-RED",
      "version": "6.2.0",
      "size": 0.0
      "slug": "core_configurator",
      "name": "File editor",
      "version": "5.0.0",
      "size": 0.0
      "slug": "core_mosquitto",
      "name": "Mosquitto broker",
      "version": "5.1",
      "size": 0.0
      "slug": "cebe7a76_hassio_google_drive_backup",
      "name": "Hass.io Google Drive Backup",
      "version": "0.100.0",
      "size": 0.0
      "slug": "a0d7b954_zerotier",
      "name": "ZeroTier One",
      "version": "0.7.1",
      "size": 0.0
      "slug": "806b11b5_zigbee2mqttassistant",
      "name": "zigbee2mqttassistant",
      "version": "0.3.147",
      "size": 0.0
      "slug": "core_duckdns",
      "name": "Duck DNS",
      "version": "1.11",
      "size": 0.02
      "slug": "15ef4d2f_esphome",
      "name": "ESPHome",
      "version": "1.14.3",
      "size": 83.56
  "folders": [
    "addons/local",
    "share",
    "ssl",
    "homeassistant"
  "homeassistant": {
    "ssl": true,
    "watchdog": true,
    "wait_boot": 600,
    "audio_output": null,
    "audio_input": null,
    "boot": true,
    "port": 8123,
    "version": "0.109.2",
    "image": "homeassistant/raspberrypi4-homeassistant",
    "refresh_token": "f705965e2b0c116c4cb490aafdc8023f6c973801d2ec5cc63c526fcef52af6fe9e4e766379a66232b55f7e421cf0f9f83071f8008a00e389d09587e42f4ba55b"
  "repositories": [
    "https://github.com/hassio-addons/repository",
    "https://github.com/sabeechen/hassio-google-drive-backup",
    "https://github.com/yllibed/hassio",
    "https://github.com/esphome/hassio"
Snapshot.json that is not working
  "slug": "78ee94b3",
  "name": "Full Snapshot 2020-06-05 17:35:56",
  "date": "2020-06-05T14:35:58.209353+00:00",
  "type": "full",
  "repositories": [
  "folders": [
    "addons/local",
    "share",
    "ssl"
  "homeassistant": {
    "watchdog": true,
    "boot": true,
    "ssl": true,
    "wait_boot": 600,
    "port": 8123,
    "version": "0.110.4",
  "addons": [
      "version": "3.3.0",
      "size": 0.0
      "name": "Node-RED",
      "version": "6.2.0",
      "size": 0.0
      "version": "5.1",
      "size": 0.0
      "size": 0.0
      "version": "5.0.0",
      "size": 0.0
      "version": "0.7.2",
      "size": 0.0
      "size": 0.0
      "name": "Duck DNS",
      "version": "1.12.0",
      "size": 0.02
      "name": "ESPHome",
      "size": 83.56
