I have an Aqara curtain motor that worked fine for years and then stopped responding. I unpaired it and re-paired it to the Aqara hub/app but it shows up as a button instead of a curtain.
I later paired it to a backup instance of home assistant, and it correctly identified it as a curtain with a zigbee ID of lumi.curtain
for model ZNCLDJ11LM
I have another 6 curtains paired to the Aqara hub/app that continue to work as expected through the HA Miio integration.
Is there anything I can do to correct this identification? Or maybe reset the zigbee module on this curtain?
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4447, maximum_buffer_size=127, maximum_incoming_transfer_size=100, server_mask=0, maximum_outgoing_transfer_size=100, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0202",
"in_clusters": [
"0x0000",
"0x0001",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x000a",
"0x000d",
"0x0013",
"0x0102",
"0x0406"
"out_clusters": [
"0x0001",
"0x0006",
"0x000a",
"0x000d",
"0x0013",
"0x0019",
"0x0102",
"0x0406"
"manufacturer": "LUMI",
"model": "lumi.curtain",
"class": "zigpy.device.Device"
