Aimero
January 9, 2025, 3:30pm
1
Hi there,
I simply need a Zigbee light sensor the gives me a Lux or Lumen or whatever I can work with.
I see that motion sensors can do that, but afaik they only report the value of the Light sensor when there is movement.
Anyone has an idea how to achieve that?
the ones at https://everythingsmarthome.co.uk/ do lux and update without the need to detect movement
Philips Hue too, I think.
MoreLinux
(More Linux)
January 9, 2025, 8:28pm
4
The Ikea VALLHORN motion sensors also constantly reports, every few seconds, the Illuminance in lux.
Aimero
January 13, 2025, 5:56am
5
HI there,
I ordered the Everything Presence One, because it runs with USB and has a steady power supply
Thanks for the recommendations. I hope this works
Unfortunately Hue sensors only update Lux on occupancy.
Mine seem to work:
They may update on occupancy as well, but they seem to update periodically on their own.
I’ll test my again, but the lux update is definitely not reactive as motion.
That’s true. It looks like every four minutes or so. If you add in motion the graph is more active.
Always can add an automation. At least we know now
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
January 15, 2025, 8:50am
11
I just bought a few of these in zigbee and they work fine…
https://www.aliexpress.us/item/3256807698597755.html .
Using Z2M
Just the lux, nothing else for $8
I Put them on a few plants.
@Sir_Goodenough Can you explain how to use these? Do they require the Tuya hub?
zuz242
(zuz242)
April 14, 2025, 5:10pm
13
The product page says zigbee, so likely to work with zigbee2mqtt on HA out of the box. Only zigbee coordinator needed.
Aimero
June 4, 2025, 6:33am
14
I just want to give a little heads up
I ended up with a Unifi UP Sense, since I already own some Unifi U6 Pro Wifi APs. They are needed for the UP Sense to connect to via Bluetooth
It reports the Light every 5 Minutes which is sufficient enough for me
It is able to function as a Temperature, Humidity, Motion and even Door Sensor. So I mounted it on a window and even saved a motion sensor there lol
mne23
(Mats Nelson)
January 11, 2026, 11:51am
15
