hello,
is the “&” allowed as described here:
https://github.com/cyklo/Bukkit-OtherBlocks/wiki/Aliases-(advanced-YAML-usage)
best regards, Stef
hello,
best regards, Stef
Yes
Sounds interesting.
Do you have a good use case for it?
I use this for my milights:
light:
- name: "Plafond"
command_topic: milight/commands/0x578/rgb_cct/1
state_topic: milight/states/0x578/rgb_cct/1
<<: &MILIGHT_PARAMS
platform: mqtt_json
brightness: true
rgb: true
color_temp: true
effect: true
effect_list: [ 0, 1, 2, 3, 4, 5, 6, 7, 8]
optimistic: false
qos: 0
xy: false
retain: true
- name: "Spot"
command_topic: milight/commands/0x578/rgb_cct/2
state_topic: milight/states/0x578/rgb_cct/2
<<: *MILIGHT_PARAMS
- name: "Keuken"
command_topic: milight/commands/0x578/rgb_cct/3
state_topic: milight/states/0x578/rgb_cct/3
<<: *MILIGHT_PARAMS
- name: "Aquarium"
command_topic: milight/commands/0x579/rgb_cct/2
state_topic: milight/states/0x579/rgb_cct/2
<<: *MILIGHT_PARAMS
- name: "Badkamer"
command_topic: milight/commands/0x578/rgb_cct/4
state_topic: milight/states/0x578/rgb_cct/4
<<: *MILIGHT_PARAMS
etc
great and thanks for the example !!
Great stuff. Using it in ui-lovelace.yaml
now and that is working great for cards which I use multiple times on different tabs
Example
aliases:
- &THERMOSTAT_BUTTONS
- type: horizontal-stack
cards:
- type: "custom:button-card"
color_type: blank-card
- type: custom:button-card
# entity: script.bedtime_ac
icon: mdi:gesture-tap
color: 'var(--accent-color)'
style:
- font-weight: bold
- color: 'var(--primary-text-color)'
action: service
service:
domain: climate
action: set_operation_mode
entity_id: climate.ethermostaat
operation_mode: 'Comforstand'
style:
- font-weight: bold
action: service
service:
domain: climate
operation_mode: 'Bespaarstand'
And then you can simply use on the tabs where you want these buttons to show up.
- <<: *THERMOSTAT_BUTTONS
