Is there a way to use the area awareness in an automation? So that you can use an automation to to things for a room you are speaking in? Like shut lights off does work orb, but for example I want to trigger something in a room I am talking in, how can I know wich assistant is triggering the automation?
Found a solution for this in another post
{{ area_name(trigger.device_id) }}
works great
I hope if you could provide a sample of using the template {{ area_name(trigger.device_id) }}
it would be a great help
