Area based naming of devices
Is it possible to have devices named after the area they are in and their function? For example all my environment sensors at the moment are named based on the room they’re in, so Office Environment Sensor, Lounge Environment Sensor etc etc, and I also add them to an area.
I know renaming devices is a lot easier than it used to be but it would be great if the entity ID were not based on the name of the device, especially now as most of the config is UI based each entity & device ID could be a UID and largly hidden from the user. It would be great if I could just change the area and the displays would reflect that.
If you consider your post as a “feature request” - then this is a proper place for it.
