Area Card with multiple cameras
is it possible to assign a specific camera to an area card?
I have a hyperion ambilight and the screen shows up as a camera. However I have an actual camera also available in that area. However, the area card always picks the ambilight camera.
How can I force it to select the actual camera in thee room?
Did you ever find the answer to this question?
Unfortunately not, but I also removed cameras from the system as I did never really use them.
I’m trying to figure out the same thing :sweat_smile:
I have the same issue.
Same situation for me, it would be nice to be able to select which camera is shown in the area card.
I have 3 cameras in the backyard. The one that shows on the Area card is the camera viewing the service courtyard, pointing straight at my bins :person_shrugging:
I have the Unifi G4 Pro doorbell which has two cameras on it. The secondary camera, the package camera, is the one home assistant has selected for the area card :man_facepalming:
To work around this for now, I created a second area called “front door step” that I’m basically not using and updated the package camera entity to use that other area.
Another workaround that worked for me was renaming the camera I didn’t want to be used.
From reading the source code, it seems the Area card uses whichever camera is returned in the first position, and it’s not sorted.
I got lucky renaming it to a name that alphabetically follows the one I wanted, but since it’s not sorted, I’m not sure if this will always work for others, but it’s woking fine for me.
This work around worked for me. I added a “z” in front of the entity name for the camera I didn’t want and the card updated to the correct camera I wanted to use.
Can confirm this works like a charm
