Bought in haste as it seemed cheap in the run up to Xmas.
Does anyone know a way of integrating this into HA? I’ve tried via motionEye, but I can’t figure it out. There is no Arenti integration or HACS repository.
The camera doesn’t seem to be Onvif.
If you still wanna know, here is how I did it.
First I installed on my PC the Program ONVIF Device Manager.
There I could log in on top left corner with my ONFIV credentials from the Arenti App and the camera´s IP is shown.
I click on the cameras IP and then on “Live Video”.
The Stream should show now. On the bottom, below the stream there is a Link visible, e.g. for me:
rtsp://192.168.1.153:8554/Streaming/Channels/101
Now I go to Home Assistant, Add Integration “Generic Camera” and for the IP Address I entered
rtsp://admin:[email protected]:8554/Streaming/Channels/101
I did not use the fields for password or user. and above PASSWORD has to be replaced with ur ONFIV password from the Arenti APP.
That did it for me.
That cam will never have the onvif, I’ve that confirmed by Arenti. and this make sense as this cam only activate when there is PIR detection. Or with the app. But this works for almost all other cam’s from that brand as they use Onvif.
