aRest and Rpi 2
Hello
I am running the aRest framework on my Pi2.
I can send curl commands to turn it on and off.
curl http://192.168.X.X:3000/digital/16/1
curl http://192.168.X.X:3000/digital/16/0
My config looks like this…
  - platform: arest
    resource: http://192.168.X.X:3000
    pins:
      16:
I am using the example app.js
// Include modules
var express = require('express');
var app = express();
var piREST = require('pi-arest')(app);
// ID & name
//piREST.set_id('34f5eQ');
//piREST.set_name('my_new_Pi');
// Example variables
//temperature = 24;
//humidity = 40;
//piREST.variable('temperature',temperature);
//piREST.variable('humidity',humidity);
// Start server
var server = app.listen(3000, function() {
    console.log('Listening on port %d', server.address().port);
When I toggle it from the front end it turns on for one second and shuts off.
I have this in the logs but the command is getting to the pi.
16-10-06 15:15:14 homeassistant.components.switch.arest: Can't set mode. Is device offline?
Am I missing something?
I know I could use a command line switch but I would like to get this working.
Thanks!
I am seeing this exact same issue on a Raspberry Pi 3. Must be something in the HA code when communicating with a Pi
