I have a simple file named test.py:
from requests import post
url = "http://localhost:8123/api/states/input_text.my_data"
headers = {"Authorization": "Bearer < then my huge long token is here >", "content-type": "application/json"}
data = {"state": "25"}
response = post(url, headers=headers, json=data)
print(response.text)
…and when I said above:
I just meant that is replaced with just the hugely long string I have generated in home assistant as a long lasting token, with no additional characters around it (not the < and not the > )… so how come when I run:
sudo python3 test.py
My input_text.my_data in Home Assistant stays “unknown” and never gets assigned the value of “25” and I get this error message instead - ?
pi@kruse-pi:/usr/share/hassio/homeassistant$ sudo python3 test.py
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 704, in urlopen
httplib_response = self._make_request(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 450, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 445, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.11/http/client.py", line 1374, in getresponse
response.begin()
File "/usr/lib/python3.11/http/client.py", line 318, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.11/http/client.py", line 287, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 489, in send
resp = conn.urlopen(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 788, in urlopen
retries = retries.increment(
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 550, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/lib/python3/dist-packages/six.py", line 718, in reraise
raise value.with_traceback(tb)
response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
File "/usr/share/hassio/homeassistant/test.py", line 7, in <module>
File "/usr/lib/python3/dist-packages/requests/api.py", line 115, in post
return request("post", url, data=data, json=json, **kwargs)
File "/usr/lib/python3/dist-packages/requests/api.py", line 59, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 587, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 701, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 547, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
So trying it another way:
curl \
-H "Authorization: Bearer < then my huge long token is here >" \
-H "Content-Type: application/json" \
-d '{"state": "fgfgfgfg"}' \
it simply returns:
curl: (52) Empty reply from server
I disabled adguard, I have turned off firewalls, and yes there is already an input_text.my_data also already created in HA… but this is on the same machine (rpi4) anyway - HA Supervised - and this is being run comletely outside of HA directly on the same host from a putty session.
What am I doing wrong?
