Argon One Active Cooling and Active Linear Cooling Addon
docker exec -it 56eab83a8a14 bash
bash-5.1# i2cset -y 1 0x01a 0xfe
bash-5.1#
So it seems to be ok ?
Yeahhhhhh it’s working !
I have auto power on when I plug it back.
THANKS A LOT ! :slight_smile:
Which addon is deprecated, btw?
community terminal addon
“deprecated warning”
Little information: it’s working for me, and I received my Argon One in may 2020, the revision is 200402v5
Any change to explain how i can auto power on? It’s a bit frustrated if there is a power outage the RPI don’t boot until i press the power button in the case. :slight_smile:
So I need to run the command docker exec -it “number” dash to activate the auto power on.
All of it within that pic. We just had a long conversation about it. Read above.
With the newest Supervisor (2021.03.3) and Core (12021.3.0) I am getting this new message (two times) in the supervisor log:
21-03-04 10:31:35 WARNING (MainThread) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of ArgonOne Active Cooling
Yeah, I think that’s an error. There is no full access requested.
Hello, i have a new argon one m.2, but i have problems to start the fan.
21-03-06 08:56:54 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 7d06b5a0_argon_one_temp!
21-03-06 08:56:54 INFO (SyncWorker_6) [supervisor.docker.interface] Cleaning addon_7d06b5a0_argon_one_temp application
21-03-06 08:56:55 INFO (SyncWorker_6) [supervisor.docker.addon] Starting Docker add-on 7d06b5a0/aarch64-addon-argon_one_temp with version 0.18
21-03-06 08:57:16 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-03-06 08:57:25 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 7d06b5a0_argon_one_temp!
21-03-06 08:57:25 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning addon_7d06b5a0_argon_one_temp application
21-03-06 08:57:26 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on 7d06b5a0/aarch64-addon-argon_one_temp with version 0.18
Your tool is running but, the fan not!
Some ideas for me?
LG Werner
And i cannot find the fan speed sensor!
I made some changes today which should solve the problem.
Fan speed sensor is there. Check developer tools. You may not be automatically adding to lovelace.
Does this link work for anyone else? I saw something similar while reading the docs and I thought I’d try it. But I think the hex is assigned per-system and I’m not sure if this will work.
Open your Home Assistant instance and show the dashboard of a Supervisor add-on.
It doesn’t work. This is the link that will be called:
http://192.168.178.108:8123/_my_redirect/supervisor_addon?addon=7d06b5a0_argon_one_temp
And I am getting a 404 error.
Yeah, I figured. Thanks for testing. That my addon thing isn’t ready yet. It works for me. But not anyone else.
Can you give me the link for ArgonOne Active Cooling on your system? On mine it is https://192.168.1.8/hassio/addon/7d06b5a0_argon_one_temp/info
Sure:
http://192.168.178.108:8123/hassio/addon/7d06b5a0_argon_one_temp/info
The ID is the same.
