You need I2C before you post in this thread. This is not for troubleshooting I2C problems.
good morning works now right?
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: ArgonOne Active Cooling
Actively keeping your Argon One cool.
Add-on version: 28d
You are running the latest version of this add-on.
System: Home Assistant OS 9.2 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2022.10.5
Home Assistant Supervisor: 2022.10.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Detecting Layout of i2c, we expect to see "1a" here.
checking i2c port 0 at /dev/i2c-0
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
checking i2c port 1 at /dev/i2c-1
10: -- -- -- -- -- -- -- -- -- -- 1a -- -- -- -- --
checking i2c port 10 at /dev/i2c-10
checking i2c port 22 at /dev/i2c-22
Port not found...
I2C Port 1
Settings initialized. Argon One Detected. Beginning monitor..
Current Temperature 44 °C
2022-10-21_07:45:17: 44C - Level 1 - Fan 0% (OFF)
Current Temperature 43 °C
Current Temperature 42 °C
Yes. It is.
I can’t seem to get this to work. It reports that ”Argon One was not detected on i2c”. Any idea how to fix this?
Edit: I rebooted a couple of more times and it just started working.
[fix-attrs.d] done.
Add-on version: 28d
System: Home Assistant OS 9.3 (aarch64 / raspberrypi4-64)
[cont-init.d] done.
[services.d] done.
Port not found...
I2C Port 255
Argon One was not detected on i2c. Argon One will show a 1a on the i2c bus above. This add-on will not control temperature without a connection to Argon One.
Current Temperature 41 °C
2022-10-28_15:17:51: 41C - Level 1 - Fan 0% (OFF)
Error: Could not open file `/dev/i2c-255' or `/dev/i2c/255': No such file or directory
Failed 98: i2cset -y "${port}" 0x01a "${fanPercentHex}"
Safe Mode Activated!
Failed 208: return ${returnValue}
ok i think it’s ok now, but how can i see the temperature on the lovalace?
Hi, addon stopped working.
This is log from HassOS I2C Configurator:
crw--w---- 1 root tty 4, 39 Jun 2 20:09 tty39
crw--w---- 1 root tty 4, 4 Jun 2 20:09 tty4
crw--w---- 1 root tty 4, 40 Jun 2 20:09 tty40
crw--w---- 1 root tty 4, 41 Jun 2 20:09 tty41
crw--w---- 1 root tty 4, 42 Jun 2 20:09 tty42
crw--w---- 1 root tty 4, 43 Jun 2 20:09 tty43
crw--w---- 1 root tty 4, 44 Jun 2 20:09 tty44
crw--w---- 1 root tty 4, 45 Jun 2 20:09 tty45
crw--w---- 1 root tty 4, 46 Jun 2 20:09 tty46
crw--w---- 1 root tty 4, 47 Jun 2 20:09 tty47
crw--w---- 1 root tty 4, 48 Jun 2 20:09 tty48
crw--w---- 1 root tty 4, 49 Jun 2 20:09 tty49
crw--w---- 1 root tty 4, 5 Jun 2 20:09 tty5
crw--w---- 1 root tty 4, 50 Jun 2 20:09 tty50
crw--w---- 1 root tty 4, 51 Jun 2 20:09 tty51
crw--w---- 1 root tty 4, 52 Jun 2 20:09 tty52
crw--w---- 1 root tty 4, 53 Jun 2 20:09 tty53
crw--w---- 1 root tty 4, 54 Jun 2 20:09 tty54
crw--w---- 1 root tty 4, 55 Jun 2 20:09 tty55
crw--w---- 1 root tty 4, 56 Jun 2 20:09 tty56
crw--w---- 1 root tty 4, 57 Jun 2 20:09 tty57
crw--w---- 1 root tty 4, 58 Jun 2 20:09 tty58
crw--w---- 1 root tty 4, 59 Jun 2 20:09 tty59
crw--w---- 1 root tty 4, 6 Jun 2 20:09 tty6
crw--w---- 1 root tty 4, 60 Jun 2 20:09 tty60
crw--w---- 1 root tty 4, 61 Jun 2 20:09 tty61
crw--w---- 1 root tty 4, 62 Jun 2 20:09 tty62
crw--w---- 1 root tty 4, 63 Jun 2 20:09 tty63
crw--w---- 1 root tty 4, 7 Jun 2 20:09 tty7
crw--w---- 1 root tty 4, 8 Jun 2 20:09 tty8
crw--w---- 1 root tty 4, 9 Jun 2 20:09 tty9
crw-rw---- 1 root audio 166, 0 Nov 9 07:36 ttyACM0
crw-rw---- 1 root audio 204, 64 Jun 2 20:09 ttyAMA0
crw------- 1 root root 5, 3 Jun 2 20:09 ttyprintk
crw------- 1 root root 10, 239 Jun 2 20:09 uhid
crw------- 1 root root 10, 223 Jun 2 20:09 uinput
crw-rw-rw- 1 root root 1, 9 Jun 2 20:09 urandom
drwxr-xr-x 2 root root 60 Jun 2 20:09 usb
drwxr-xr-x 3 root root 60 Jun 2 20:09 v4l
crw------- 1 root root 245, 0 Jun 2 20:09 vc-mem
crw------- 1 root root 239, 0 Jun 2 20:09 vchiq
crw------- 1 root root 10, 125 Jun 2 20:09 vcio
crw-rw---- 1 root tty 7, 0 Jun 2 20:09 vcs
crw-rw---- 1 root tty 7, 1 Jun 2 20:09 vcs1
crw-rw---- 1 root tty 7, 2 Jun 2 20:09 vcs2
crw-rw---- 1 root tty 7, 3 Jun 2 20:09 vcs3
crw-rw---- 1 root tty 7, 4 Jun 2 20:09 vcs4
crw-rw---- 1 root tty 7, 5 Jun 2 20:09 vcs5
crw-rw---- 1 root tty 7, 6 Jun 2 20:09 vcs6
crw-rw---- 1 root tty 7, 128 Jun 2 20:09 vcsa
crw-rw---- 1 root tty 7, 129 Jun 2 20:09 vcsa1
crw-rw---- 1 root tty 7, 130 Jun 2 20:09 vcsa2
crw-rw---- 1 root tty 7, 131 Jun 2 20:09 vcsa3
crw-rw---- 1 root tty 7, 132 Jun 2 20:09 vcsa4
crw-rw---- 1 root tty 7, 133 Jun 2 20:09 vcsa5
crw-rw---- 1 root tty 7, 134 Jun 2 20:09 vcsa6
crw-rw-rw- 1 root root 10, 122 Jun 2 20:09 vcsm-cma
crw-rw---- 1 root tty 7, 64 Jun 2 20:09 vcsu
crw-rw---- 1 root tty 7, 65 Jun 2 20:09 vcsu1
crw-rw---- 1 root tty 7, 66 Jun 2 20:09 vcsu2
crw-rw---- 1 root tty 7, 67 Jun 2 20:09 vcsu3
crw-rw---- 1 root tty 7, 68 Jun 2 20:09 vcsu4
crw-rw---- 1 root tty 7, 69 Jun 2 20:09 vcsu5
crw-rw---- 1 root tty 7, 70 Jun 2 20:09 vcsu6
crw------- 1 root root 10, 127 Jun 2 20:09 vga_arbiter
crw------- 1 root root 10, 137 Jun 2 20:09 vhci
crw-rw-rw- 1 root 111 10, 238 Jun 2 20:09 vhost-net
crw-rw-rw- 1 root 111 10, 241 Jun 2 20:09 vhost-vsock
crw-rw---- 1 root netdev 81, 5 Jun 2 20:09 video10
crw-rw---- 1 root netdev 81, 6 Jun 2 20:09 video11
crw-rw---- 1 root netdev 81, 9 Jun 2 20:09 video12
crw-rw---- 1 root netdev 81, 0 Jun 2 20:09 video13
crw-rw---- 1 root netdev 81, 1 Jun 2 20:09 video14
crw-rw---- 1 root netdev 81, 2 Jun 2 20:09 video15
crw-rw---- 1 root netdev 81, 3 Jun 2 20:09 video16
crw-rw---- 1 root netdev 81, 11 Jun 2 20:09 video18
crw-rw---- 1 root netdev 81, 7 Jun 2 20:09 video19
crw-rw---- 1 root netdev 81, 4 Jun 2 20:09 video20
crw-rw---- 1 root netdev 81, 8 Jun 2 20:09 video21
crw-rw---- 1 root netdev 81, 10 Jun 2 20:09 video22
crw-rw---- 1 root netdev 81, 13 Jun 2 20:09 video23
crw-rw---- 1 root netdev 81, 12 Jun 2 20:09 video31
crw------- 1 root root 10, 130 Jun 2 20:09 watchdog
crw------- 1 root root 247, 0 Jun 2 20:09 watchdog0
crw-rw-rw- 1 root root 1, 5 Jun 2 20:09 zero
brw-rw---- 1 root disk 254, 0 Jun 2 20:09 zram0
brw-rw---- 1 root disk 254, 1 Jun 2 20:09 zram1
brw-rw---- 1 root disk 254, 2 Jun 2 20:09 zram2
/dev/i2c-1
/dev/i2c-0 /dev/i2c-1 /dev/i2c-10 /dev/i2c-22
Found i2c access! Nothing to do! You can remove this add-on.
This is log from ArgonOne Active Linear Cooling:
[fix-attrs.d] done.
Add-on: ArgonOne Active Linear Cooling
Add-on version: 27
Home Assistant Core: 2022.11.2
Home Assistant Supervisor: 2022.10.2
[cont-init.d] done.
[services.d] done.
00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
Current Temperature = 46 °C
2022-11-09_08:11:05: 46C - Fan 10% | hex:(0xa)
Error: Write failed
Failed 67: i2cset -y 1 0x01a "${fanPercentHex}"
Error: Write failed
Failed 133: return ${returnValue}
Error: Write failed
Check the hardware connections
Has there been an update in the past few days? I have my addon set to auto update and the addon will no longer start since about 2 days ago. I’m running the Linear version on a RPi4
[fix-attrs.d] done.
Add-on version: 28
Home Assistant Core: 2022.11.3
[cont-init.d] done.
[services.d] done.
10: -- -- -- -- -- -- -- -- -- -- -- 1b -- -- -- --
Port not found...
/run.sh: line 108: thePort: unbound variable
[cmd] /run.sh exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Are you using the argon one repo, or the Addons repo?
Addons repo
To clarify I mean this repo. GitHub - adamoutler/Addons
I’m not able to reproduce. Try uninstalling and reinstalling.
I was using an old repo by the looks of it. I’ve added the one you suggested and reinstalled but still getting the same error message.
I am experiencing the same problem.
I’m not sure what to say. I just reinstalled both. I adjusted no settings, and just started the app with i2c enabled beforehand.
Heres’ my startup log from Argon One Active Linear cooling Pastebin
Here’s my startup log from Argon One Active Cooling Pastebin
Yes that is what is showing for me. I actually have the Argon Neo but it has always worked with the Argon One Linear addon.
Can you try git cloning the repository into your /addons folder from the terminal and ssh addon, then modifying the 1a to match your output? I can add a check to find 1b if it works. This should work with the linear cooling app.
Would you be able to provide steps on what commands I need to run please?
Been trying to figure this out for the best part of a week but not getting anywhere. Hopefully I can revert back to the old Argon script method until I figure this out.
The Classic addon should work for Neo. I forked it before adding the calibration I don’t have a way to test changes so I’m hesitant to add code for those device.
