benjani85
(Benjani85)
November 29, 2022, 9:26am
439
Just to confirm, you are referring to ArgonOne Active Cooling addon right?
Hereβs the log output from that addon:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: ArgonOne Active Cooling
Actively keeping your Argon One cool.
Add-on version: 28d
You are running the latest version of this add-on.
System: Home Assistant OS 9.3 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2022.11.4
Home Assistant Supervisor: 2022.11.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Detecting Layout of i2c, we expect to see "1a" here.
checking i2c port 0 at /dev/i2c-0
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
checking i2c port 1 at /dev/i2c-1
10: -- -- -- -- -- -- -- -- -- -- -- 1b -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
checking i2c port 10 at /dev/i2c-10
checking i2c port 22 at /dev/i2c-22
Port not found...
I2C Port 255
Argon One was not detected on i2c. Argon One will show a 1a on the i2c bus above. This add-on will not control temperature without a connection to Argon One.
Current Temperature 44 Β°C
2022-11-29_22:22:45: 44C - Level 1 - Fan 0% (OFF)
Error: Could not open file `/dev/i2c-255' or `/dev/i2c/255': No such file or directory
Failed 98: i2cset -y "${port}" 0x01a "${fanPercentHex}"
Safe Mode Activated!
Failed 209: return ${returnValue}
benjani85
(Benjani85)
November 30, 2022, 6:55am
440
I also tried the βArgonOne Active Linear Cooling - Classicβ addon but got this error:
500 Server Error for http+docker://localhost/v1.41/build?t=2ad4c73a%2Faarch64-addon-argon_one_temp_linear_Linear%3A27&q=False&nocache=False&rm=False&forcerm=True&pull=True&buildargs=%7B%22BUILD_FROM%22%3A+%22ghcr.io%2Fhassio-addons%2Fbase%2Faarch64%3A9.1.7%22%2C+%22BUILD_VERSION%22%3A+%2227%22%2C+%22BUILD_ARCH%22%3A+%22aarch64%22%7D&labels=%7B%22io.hass.version%22%3A+%2227%22%2C+%22io.hass.arch%22%3A+%22aarch64%22%2C+%22io.hass.type%22%3A+%22addon%22%2C+%22io.hass.name%22%3A+%22ArgonOne+Active+Linear+Cooling+-+Classic%22%2C+%22io.hass.description%22%3A+%22Actively+keeping+your+Argon+One+cool.%22%2C+%22io.hass.url%22%3A+%22https%3A%2F%2Fcommunity.home-assistant.io%2Ft%2Fargon-one-active-cooling-addon%2F262598%2F%22%7D&platform=linux%2Farm64: Internal Server Error ("invalid reference format: repository name must be lowercase")
Yagyu
December 2, 2022, 8:04am
441
Iβve noticed in the meantime that the addon doesnβt run correctly after restarting Hassio.
The temperature is displayed correctly in the log, but the fan runs continuously even if the log shows a temperature below the low range.
An addon restart solves the problem and then the fan runs as set.
Is there a solution to the problem?
thanks
Here also the same issue: fan runs continously
adamoutler
(Adam Outler)
December 2, 2022, 11:19pm
443
Probably needs a timeout on the networking for reporting fan speed.
benjani85
(Benjani85)
December 5, 2022, 7:47am
444
Is there are way that I can run an older version of the addon before this became an issue? I donβt like to have the fan running 100% all of the time.
adamoutler
(Adam Outler)
December 6, 2022, 12:59am
445
I added a detection for the Argon One Neo in version 29a. I also noticed it would always use the last i2c device and corrected that. Please update and see if this works for you.
It is available in the Argon One repository now. It will be available in the general Addons repository at 00:00EST.
Nothing changed with 29a and a restart still cant find i2c
benjani85
(Benjani85)
December 6, 2022, 11:50pm
447
Same for me unfortunately
[fix-attrs.d] done.
Add-on: ArgonOne Active Linear Cooling
Add-on version: 29a
Home Assistant Core: 2022.11.5
[cont-init.d] done.
[services.d] done.
[cmd] /run.sh exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
oferbar
(Oferbar)
December 7, 2022, 2:46pm
448
I installed 29a, but now itβs not working as before. Nothing else was changed, just the addon.
Any advice? Thanks
[s6-init] making user provided files available at /var/run/s6/etcβ¦exited 0.
[s6-init] ensuring user provided files have correct permsβ¦exited 0.
[fix-attrs.d] applying ownership & permissions fixesβ¦
[fix-attrs.d] done.
[cont-init.d] executing container initialization scriptsβ¦
[cont-init.d] 00-banner.sh: executingβ¦
Add-on version: 29a
[cont-init.d] 01-log-level.sh: executingβ¦
[cont-init.d] done.
[services.d] done.
Detecting Layout of i2c, we expect to see β1aβ here.
00: β β β β β β β β
10: β β β β β β β β β β β β β β β β
20: β β β β β β β β β β β β β β β β
30: β β β β β β β β β β β β β β β β
40: β β β β β β β β β β β β β β β β
50: 50 β β β β β β β β β β β β β β β
60: β β β β β β β β β β β β β β β β
70: β β β β β β β β
00: β β β β β β β β
10: β β β β β β β β β β β 1b β β β β
50: β β β β β β β β β β β β β β β β
70: β β β β β β β β
00: β β β β β β β β
70: β β β β β β β β
00: β β β β β β β β
70: β β β β β β β β
[cont-finish.d] executing container finish scriptsβ¦
[cont-finish.d] 99-message.sh: executingβ¦
adamoutler
(Adam Outler)
December 7, 2022, 7:12pm
449
is this a Neo? I guess we can acknowledge that itβs on 1b, but send commands to 1a?
adamoutler
(Adam Outler)
December 7, 2022, 7:23pm
450
someone with a Neo, please do this.
install SSH & Terminal addon
disable protection mode, and start addon.
docker container ls
to find the container id
docker exec -it <container id> bash
I need the results of these commands
i2cset -y 1 0x01a 0x01
i2cset -y 1 0x01a 0xEE
i2cset -y 1 0x01b 0xEE
i2cset -y 1 0x01b 0x00
the 0xEE sets the fan to a high speed. 0x00 sets the fan to off.
on mine I communicate with the β1aβ device, I expect on yours, youβd communicate with the β1bβ device. Please confirm this and Iβll make changes.
oferbar
(Oferbar)
December 7, 2022, 8:10pm
451
Thanks for the info.
Are you asking if I have an Argon NEO case?
The answer is no.
The Rpi4 came with a kit from CanaKit:
I bought the Argon recently to keep it cooler, itβs from Amazon:
I had to work the case for fitting but it go in.
If it wasnβt clear from my previous post, I did get the Argon Addon working with v28.
However, after upgrading to 29a I noticed that the addon is not starting and thatβs the error log that I attached.
I restored back to the v28, but now it still gives the same error and not working.
I am using the ArgonOne Active Linear Cooling, because the other one did not work.
In the Addon there is no Protection Mode button:
Any ideas?
Thanks!
benjani85
(Benjani85)
December 7, 2022, 8:44pm
452
I didnβt get long to run these commands since the addon only runs for a few seconds and then the container is removed but here is what I got:
root@2ad4c73a-argon-one-temp-linear:/data$ i2cset -y 1 0x01a 0x01
root@2ad4c73a-argon-one-temp-linear:/data$ i2cset -y 1 0x01a 0xEE
root@2ad4c73a-argon-one-temp-linear:/data$ i2cset -y 1 0x01b 0xEE
Error: Write failed
root@2ad4c73a-argon-one-temp-linear:/data$ i2cset -y 1 0x01b 0x00
Error: Write failed
I seem to remember it was communicating on 1a before so not sure why it shows 1b in the addon logs. I have been using Argon Neo for most of this year with the latest version of the addon and it has worked without any issues.
adamoutler
(Adam Outler)
December 7, 2022, 10:36pm
453
Thanks. Iβm pushing changes out now. It should work with Version 29b. I think the next window for release to Addons repository is in about 2 hours. Itβs available immediately in Argon One repository.
benjani85
(Benjani85)
December 8, 2022, 1:59am
454
Bad news Iβm afraidβ¦
[fix-attrs.d] done.
Add-on version: 29ab
[cont-init.d] done.
[services.d] done.
adamoutler
(Adam Outler)
December 8, 2022, 2:31am
455
Version 29c should correct it. I noticed the 1b was actually off by one spot. It was in the 1a slot instead of 1b. Lets try that again. Argon One repo- available now, Addons repo- 4 hours.
oferbar
(Oferbar)
December 8, 2022, 2:26pm
456
That seem to solve the issue!
Thank you so much for your effort!
[fix-attrs.d] done.
Add-on version: 29c
Home Assistant Core: 2022.12.0
[cont-init.d] done.
[services.d] done.
00: β β β β β β β β
70: β β β β β β β β
not found on /dev/i2c-0
00: β β β β β β β β
70: β β β β β β β β
found at /dev/i2c-1
I2C Port 1
Settings initialized. Argon One Detected. Beginning monitorβ¦
Current Temperature = 47 Β°C
2022-12-08_16:22:06: 47C - Fan 10% | hex:(0xa)
benjani85
(Benjani85)
December 8, 2022, 8:01pm
457
Working for me too. Thanks so much for taking the time to get it resolved!
I still have this:
[fix-attrs.d] done.
Add-on version: 29c
Home Assistant Core: 2022.12.1
[cont-init.d] done.
[services.d] done.
not found on /dev/i2c-1
not found on /dev/i2c-10
not found on /dev/i2c-22
I2C Port 255
Current Temperature 35 Β°C
2022-12-09_11:16:59: 35C - Level 1 - Fan 0% (OFF)
Failed 98: i2cset -y "${port}" "0x01a" "${fanPercentHex}"
