Try adding “force_image”:true to the data json from notification. If that image is from your server and your server is behind a SSL self signed certificate, Android will not going to know how to access it. So putting that force_image will make Ariela download that. Please let me know if works.
Devices on map appear only after clicking on their badges. Refreshing the dashboard makes them dissapear again, and I need to click on their badges again. Anyone else experiencing this?
Home assistant grabs the snapshot from my local blue iris server. Then home assistant send the snapshot to ariela. I didn’t think this would be a problem.
Yes, but the snapshot will be local, and passing it as local will work when Ariela is local connected. But when Ariela is external, it will receive a local ip which is not accessible.
I have in plan adding documentation for all sensors in the fallowing days.
:edit: I’ve just realized ariela isn’t for iPhone, duh. Still asking about my OnePlus though.
I’ve been using this app for a week or so now and it’s pretty great.
'I have an issue with setting up sensors using mobile_app. I get duplicates of the sensors, and I haven’t been able to find a solution searching around. Happens with my work iPhone and my OnePlus 6t phone. Anyone have any thoughts on this?
I’ve gone through this, and now I can see device_tracker. but the sensors are still not showing up. U have both Device Tracker, and Device Tracker - Mobile APP turned on in settings, and I’ve gone into the sensor section and selected the ones I want to show.
Hi, got another question
When I disconnect bluetooth device, Ariela sends MQTT as intended. Problem is, when I disable bluetooth on my phone, and then enable it again, it sends last message again (which then leads to wrong device location).
In MQTT options in ariela “retain” option is turned off
Is there another option or reason why when bluetooth turned on it sends last message again or am I doing something wrong?
