If I open up the picture right after it was processed I see the different time stamps on the picture. So the picture is definitely not the same, when the notification gets fired.
I understand - so it could be because of the connection to firebase, because I do have full signal and I also do stuff on the Internet while I gets these multiple notifications.
11 seconds its not that much. Maybe you can also put in the notification the timestamp when it was send from HA. In this way you will have a better comparison?
I managed to track down the crashing due to location permissions. If location permissions is set to “Deny”, the app doesnt crash when selecting settings. If the settings are set to “Allow all the time” or
“Allow only while using the app”, the app will crash when opening settings.
Clearing the cache works because it will reset the location to “Deny”. Once location tracker is turned on, it will crash any time the settings are opened.
Hey again,
I think I might have mentioned this before, I just couldn’t find it though, so here it comes.
When using Ariela and enables UI --> Web UI and Lovelace UI, all sliders (light/volume) seems to be unresponsive. If I gently push on the slider area it it sometimes changes, but if I try to slide it up or down, nothing happens.
If I open up a browser on the phone or on a computer, it slides perfectly.
