Hello all,
A New function which will be available in the app very soon: quick launch. Please check it out and let me know if you like it or not
Hello all,
I’m using Ariela Widgets but they become unresponsive after a day.
I have several Ariela Widgets connected to HA Template Switches. They work great. However, if I don’t use them for a day then they stop working. Starting the Ariela app fixes the problem.
Seems the Widgets need the app to have run in the last 24 hours?
Have others seen this problem? Same thing happens on my phone and on my tablet. If it’s just me then I’ll probably try to factory reset the phone or something.
Please enable debug mode in Ariela, reproduce the problem and send me the logs so i can check it out.
Is custom button-card on the pipeline? Where can I request it?
Thanks for this app is the only app that works on my old android!
The best app for old devices by far!
Are others using Areila Widgets and not also use the Ariela app? I can’t get them to work.
The Widgets stop working if the app isn’t started every 24 hours. So if you I don’t start the app every 24 hours the Widgets break and my wife complains. Trying to figure out if it’s just me or if everyone has this problem.
Ionut, I sent you my logs a couple weeks ago to the email address in Ariela. If you’re not getting my emails then just let know and we can find another way to communicate.
Please try to contact me again using Ariela contact feature.
Hi Ionut. I wanted to upgrade my HA to the latest to make sure that wasn’t the problem. I’ve since reproduce the problem with Ariela again. I just sent the log to your email using Ariela’s Contact feature.
Let me know if you can reproduce it.
Thank you for contacting me. Please check my reply and let me know if I can send you a version of Ariela on which I’ve currently worked.
Hello
Ariela 1.4.0 is finally in the play store.
What’s new:
Download: https://play.google.com/store/apps/details?id=com.surodev.ariela
Ariela 1.4.2 is out:
What’s new:
Hello everybody,
Version 1.4.3 is out.
What’s new:
Tutorial - Ariela: Enable Assistant Mode
Tutorial - Access [#homeassistant] server from the outside local network and without a dynamic DNS service using Ariela: Ariela: Access Home Assistant server without a dynamic DNS service – Ariela
Please test it and let me know how it goes. Thank you.
Thanks and Happy New Year!
One minor niggle with glances card- ineffective screen usage- wraps after 3rd item so 4th is on a new line but edges are wide (in both orientations)- it should fit
Best, JR
Happy New Year! Could you please post a screenshot of the issue, please? Thank you.
I understand now the issue. I will modify Ariela to take into account the “Columns” attribute so it can display the entities much better.
Regarding issues reporting, you can do that on Github too at: https://github.com/MCrissDev/Ariela/issues
Version 1.4.4 is out:
What’s new:
Version 1.4.5 is out.
What’s new:
Hi this is a great app
But what does it take to make this Custom Alarm Panel Card to work i Ariela???
Thank you. I could add native support for that card or at least make it act as the alarm card it is implemented now.
