Ariela - Home Assistant Android Client
Hi Ionut,
So the above seem to do the trick - tried to delete and readd and now it works.
The port forwarding also seems to work. The app successfully opens the ip on the port chosen and accepts the password.
Thanks - looks good so far!
Request: Add support for ip cams
Hello Yoinkz,
Glad to hear it works. I will add support for IP webcams soon.
Best regards,
Ionut
I am interested
I am also interested in testing. thank you
Use same link as before for downloading the apk. Please let me know how it goes.
Added support for Dark Sky widget.
With Lovelace now there is less of a need for an Android app. While, to me at least, there is a BIG need for widgets.
Imagine being able to press a button on your home screen to turn on a light/switch/scene, without the need to open the app (or the browser with lovelace).
Or beeing able to read a sensor without opening the app/browser
So do you want widgets support in the application?
I will see what i can do about that.
Ionut
Yes I think thats the missing part of HASS in general. Many times it takes too long to open Lovelace (or your app, or any app), to just turn on a light/switch/scene, or to watch the status of a light/switch/sensor and so on.
There is another android app but the development has stopped, it had widget but too limited and font very small and almost unreadable
I understand. Let me see what i can do about this.
Ionut
Is there a way of adding support for Android Actionable Notifications at all?
I’m not sure if this is something you need to add or something the other Dev needs to add?
This looks great though, can’t wait to try it.
I can add that functionality too.
Interested
Cool. Are you making the source open or closed?
For now the project is going to be closed source. If someone wants to contribute on it i will share the source code to those persons.
Ionut
You can just use Tasker or other similar app to call HA API:
Since a tasker task can be placed as a widget in the home screen, that should do the trick.
I find Tasker very difficult to program (its my limitation).
I found a great product HTTP SHORTCUT
which does a good job for light/switch/scene/script, but unfortunately is only Android (half family uses Ios)
I am missing also a Sensor widget (basically a display of a value)
I would say to concentrate on widget for SENSORS
I can test it. Really interrestet.
Klagio: i will do that.
Also you can download APK from here: http://surodev.com/ariela/app-release.apk
Also: now i am working on a way to add switches / lights etc as a simple home icon. When you will click that icon it will turn on switch / light.
Ionut
